| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi ! Is a regulated power supply necessary for an active filter ? I will be using this filter as a subsonic filter.
#2 |
you can use something like this
#3 |
I asked this question because I am stuck with 9-0-9 auxiliary supply from a main transformer thats powering my amplifier. Thus i don't have enough voltage to use a 12V regulator which usually requires the Vin min to be at least around 14V. So is it ok if i don't use a regulated power supply for the active filter ?
#4 |
LM337 and LM117 are working from 3 to 30 V see their datasheets , at this supply you can connect your 9-0-9 .and get from 3-0-3 V to 9 0 9 V
#5 |
it's better if you'll use regulated power supply , you can hear 50HZ hum if use a not regulaated , or you can try only a el. capacitor and ceramic shunt capacitor
see that http://www.masterkit.ru/info/magshow.php?num=61 i have build it and it's very good filter and it have regulated power on the same board if something you don't undersatand ask me i know russian ! |
| 3 Pin regulated supply VS zener based supply | KevinLee | Solid State | 3 | 15th September 2008 02:40 PM |
| active filter from rod elliot and sub filter questions | wuffer | Parts | 0 | 2nd October 2005 01:12 PM |
| regulated supply for GC | yuval | Chip Amps | 9 | 16th April 2004 09:06 AM |
| Single supply active filter | Maryus17 | Everything Else | 5 | 24th February 2004 09:59 PM |
| regulated 5V DC supply | Tomatito | Tubes / Valves | 50 | 4th February 2003 08:33 PM |
| Page generated in 0.08013 seconds (72.15% PHP - 27.85% MySQL) with 11 queries |
