Go Back   Home > Forums > Design & Build > Parts
Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Thread Tools
Old 20th June 2009, 02:13 AM   #1
Default Surface mount components for analogue audio... Yes or no???
Hi.
I'm just wondering what people's thoughts are on using surface mount components for analogue preamps. Mounting them isn't an issue in this case, and because of the physically smaller footprint I'd prefer to use them (lots to pack in to the case!!!).
I'd like to go all out with surface mount - Op-amps, resistors, capacitors, etc.
What's people's thoughts on this? I don't want any loss in quality of output or componentry by using these.
Cheers!
Old 20th June 2009, 02:33 AM   #2
Send a message via MSN to bacon665
If you canw ork them then go for it but keep in mind they cant take the abuse their larger kin can and that cooling can be an issue
Old 20th June 2009, 02:45 AM   #3
Mr Evil is offline Mr Evil
I use them quite a lot. They're great when you need to squeeze things down into the smallest possible space, and you get a wider selection of some types of components.
Old 20th June 2009, 02:52 AM   #4
jcx is offline jcx
power dissapation has to be watched
for resistors going NiCr is relatively cheaper though
there is little choice in signal path C - PPS is likely the best smt film - also hand soldering smt flim can be difficult due to melting the cap
Old 20th June 2009, 03:01 AM   #5
Cool, thanks for that! Good point about the cooling. My prototypes will be all PDIP etc so I can see how hot things get then. I was thinking about cooling the other day, this project is going to have something like 150 op-amps in a 4U case!!! I'm thinking a proper 100 hour test may be necessary - I need these things to go the distance!!!
Old 20th June 2009, 09:08 PM   #6
star882 is offline star882
star882's Avatar
Almost every modern sound card uses surface mount components on both the digital and analog sides. In fact, some sound cards have no through hole components at all.
Get OpenOffice.org!
Old 21st June 2009, 12:32 AM   #7
Thanks. I don't normally consider soundcards to be of great audio quality anyway, unless its a PCI M-Audio (or similar) analogue card. Even then, they're still pretty bottom range as far as the professional industry goes. Some of the better brands do PCI/PCI-E cards, but these are normally digitally based.
I'm more referring to using surface mount in professional analogue preamps - Rackmount or Home Theatre.
Thanks for your input though!
Old 21st June 2009, 01:05 AM   #8
Jackass of All Trades
BrianDonegan's Avatar
There is a great range of thin-film surface mount resistors available, which will give you much lower noise than thick-film. You also get shorter pathing and tighter bypassing capabilities (caps).
If you use ceramic caps, try hard to stick to C0G/NP0 rated caps (usually available up through .1uF), falling back to X7R for larger values if needed (up to >10uF).
Abiding Diax's Rake
Old 21st June 2009, 01:15 AM   #9
Great! That's the sort of information I love to hear!!! Thanks heaps!
Old 21st June 2009, 02:22 AM   #10
I don't have any (mental) problem with SMT except for caps. There are times when a COG can't be had in a large enough value (or would be the size of a Buick), and only a film will do. It's assumed you'll use a properly designed multi-layer board, so cooling shouldn't be a huge issue.
What's in *your* junk box?
Thread Tools
Surface mount components! ungie Swap Meet 12 25th September 2009 01:41 PM
Surface mount components poorly regarded jwb Parts 51 1st March 2009 12:20 AM
Surface mount drive components? ak_47_boy Class D 3 10th June 2008 06:53 AM
Soldering Surface Mount Components Ulas Digital Source 2 14th April 2006 02:38 AM
Page generated in 0.09480000 seconds (80.48% PHP - 19.52% MySQL) with 11 queries
Copyright ©1999-2010 diyAudio
