| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#21 | |
Audio Junkie
Sparkfun has an excellent toaster over reflow controller kit for $89!!! |
#22 | |
Audio Junkie
Don't even get me started on Crown and SMD stuff....yuck. that whole CE series of amps...junk! and i hate saying that about crown but wow. I tell CE series customers, to throw that thing away and buy one of the new $299 QSC's! |
#23 | |
however, I have 2 modded crown IC-150's with National's hotted up opamps and Jung-Didden super-regs and they sound fantastic. |
#24 |
SMD is really cool, I like it a lot. Also has the nice advantage that parts values are directly written upon the part, no color schemes to learn
I find the thin film Susumu resistors very nice and they are readily available from Digikey and Farnell. Through hole parts, however, have the nice advantage that one can use them as bridges in 2 layer designs, as bridge across tracks and as bridge from top to bottom. That's hardly possible with SMD-parts. Have fun, Hannes
fresh matched IRFP240/IRFP9240 fets F5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#25 |
http://www.diyaudio.com/forums/showt...56#post1886356
Look at how much has been squeezed into this tiny PCB. It is little bigger than the two FETs underneath it. A great implementation of SMD in Audio.
regards Andrew T. |
#26 |
A good source of info and footprint information for SMD components can be found at PCB Matrix:
http://www.pcbmatrix.com/downloads/ They have done a lot of work related to IPC-7351 and the document "The CAD library of the Future" is worth a read. If you are moving to SMD or already use it, working to the IPC-7351 specification is recomended, a lot of the donkey work been done (downloadable calculators, documentation etc). With the downloadable (FREE) viewers and calculators all the footprints for 99% of any SMD device you will require have been done for you, you just have to copy the geomatry to your own CAD library. |
#27 |
Cool, thanks!
| Surface mount components poorly regarded | jwb | Parts | 52 | 7th September 2010 04:27 PM |
| Surface mount components! | ungie | Swap Meet | 12 | 25th September 2009 02:41 PM |
| Surface mount drive components? | ak_47_boy | Class D | 3 | 10th June 2008 07:53 AM |
| Soldering Surface Mount Components | Ulas | Digital Source | 2 | 14th April 2006 03:38 AM |
| Page generated in 0.09264 seconds (76.23% PHP - 23.77% MySQL) with 11 queries |
