LT1962 misbehaving - why? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th June 2009, 11:45 PM   #1
Default LT1962 misbehaving - why?
I'm building balanced to unbalanced converter on OP727 -> optoresistor volume control. I'm using LT1962 and LT1964 in the power supply. I don't see any problem with LT1964 so far, but LT1962 oscillates.
LT1962 oscillates at about 80Hz (sawtooth) loaded on 20uF OS-CON, it also oscillates with higher ESR capacitors (BG) as well. Oscillation amplitude is about 0.2V.
It is also oscillates loaded just at TL074 + 2 LEDs. Oscillation in that case depends on LEDs current.
LT1962 used in the standard circuit from datasheet with 18v input ant 14v output.
I checked my PCB number of time it should be correct.
Is there are some specifics in using LT1962? Are they generally behaving this way, or I just got ICs from bad batch?
Thanks,
Viktor
Old 19th June 2009, 09:53 AM   #2
h_a is offline h_a  Europe
h_a's Avatar
No way 0.2V oscillation is normal behaviour for any regulator that deserves the name.
What is the dropout voltage in your supply?
Have fun, Hannes
High Octane phono preamp Wiki
Old 19th June 2009, 02:41 PM   #3
Oscillation is worse under load (30mA)
Dropout voltage according to design is about 4V.
It is actually second stage of the regulator. The first is simplest transistor + zenner + resistor regulator to make 18-20V (so input will be within operational limits of LT1962) from 60v power amp input/driver stage rail.
I probably will replace LT1962 with LT1761 or LT1086. LT1962 package is inconvenient to use with DIY PCB anyway.
Old 22nd June 2009, 02:01 AM   #4
dmills is offline dmills  United Kingdom
What value (and what type) is the cap across the input of the regulator?
An excessively high source impedance can cause squegging which may well be what you are seeing.
Regards, Dan.
Old 31st July 2009, 01:23 AM   #5
Sorry, couldn't reply sooner...
Capacitor at the input didn't help. Got LT1761 in the yesterday mail.
Old 27th October 2009, 09:48 PM   #6
Project had been put aside because of absence of time till 2 weeks ago.
Solution was pretty simple: WIMA capacitor on BYP picked up interference from Mastech "lab" PSU. Changing the capacitor to 1206 one helped a lot
WTB: LT1962/762 & Pcm2707/6 hifi Swap Meet 4 17th October 2006 10:49 AM
Help diagnose misbehaving aleph-x prototype jwb Pass Labs 3 6th January 2003 02:57 AM
Comparsion of LT1962, ADP3338, REG104 regulator chengtaw Solid State 1 3rd December 2002 01:36 AM
Copyright 1999-2017 diyAudio
