| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Account Disabled
I dont have a need to, but in the event of more needed power, is it possible to parallel 7812 chips to achieve more than 1A of current?
Loading resistors would be used to regulate the load sharing. -Paul |
#2 |
The usual solution is to drive an external transistor.
#3 |
Account Disabled
Much better idea!
Thanks |
#4 |
7812 or other voltage regulators are low output impedance voltage source. Even very tiny output voltage difference between two 7812 chips would lead to a large amount of current flowing between them.
Take a look at the 78XX application note and there are simple methods to increase its current capability. One suggestion would be using bypass transistor. |
#5 |
diyAudio Moderator Emeritus
The 78S12 is 2 amp. Cheers, |
#6 |
Uhm, you're off by 20 times. The S series are Small, for 100mA or so...in TO-92 cases.
Unless I missed something in the past 5 years...(likely since I'm a toob guy )Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#7 |
diyAudio Senior Member
Hi Tim,
D'Haen is a toob guy, so are you and so am I... One thing I know though the S version is good for 2A. The T version is even good for 3A. Cheers,
Frank |
#8 |
Ah, but the "S" version is TO220
#9 |
100mA is most commonly 'L'.
#10 |
Ohhhh yeah, that's it, L. My bad.
Tim
| Parallel with different chips! | Matthewong | Chip Amps | 18 | 2nd September 2011 03:17 PM |
| gainclone chips in Parallel | steven344 | Chip Amps | 2 | 21st November 2005 05:52 PM |
| Elegant way to feed parallel data-input DAC chips ? | Bernhard | Digital Source | 27 | 18th April 2005 10:28 PM |
| Active Feedback on Parallel Chips | Stocker | Chip Amps | 8 | 4th May 2004 10:40 PM |
| Balanced or parallel DAC chips | A 8 | Digital Source | 32 | 18th March 2003 03:22 PM |
| Page generated in 0.09152 seconds (79.78% PHP - 20.22% MySQL) with 10 queries |
