diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   can I use this transformer to power the opamp based preamp? (http://www.diyaudio.com/forums/parts/146000-can-i-use-transformer-power-opamp-based-preamp.html)
zome 16th June 2009 04:30 PM
I'm not sure what the label means. It says 22V----0----22V. (please see picture)
Does it mean already it has 22V and -22V?
If it's not (I'm a newbie, as you can see), is it possible to make it + and - rails? (More precisely I want +15 and -15, I guess I can use 7815 and 7915 voltage regulator?)
http://tmeta.com/static/images/P1040868.JPG
thank you!
454Casull 16th June 2009 05:22 PM
The 22-0-22 is too much for +/- 15V, while the 12-0-12 is too little. You can use the 12-0-12 winding with 7812/7912.
cbdb 16th June 2009 05:40 PM
Not to mention its a 300 watt transformer when 30 would probably be overkill.
Minion 16th June 2009 11:27 PM
You can use the 12v-0v-12v to get +/- 15v Unregulated , it will probably be closer to +/-17v but many Opamps can handle +/-18v , but 12v regulators would be better .....
The transformer would be good for a Dual chip Gainclone with a Preamp and/or active EQ section ......
Copyright 1999-2017 diyAudio
