| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi, hope you can help me. I need to replace two BD370B transistors and understand that they are obsolete. Is there anybody that can recommend me a current replacement and possibly an address in the UK I can get them (only need 3)?
Many thanks, Rene. |
#2 |
hello.
this is a pnp af - driver transistor.......60v/1,5a/2,5w/hfe=100.....400/min. 50 meghz/ c b e i think there are some transistors that will work (perhaps a bd138-16 or bd140-16 could do it........).but the problem is the transistor case and the pin layout,it is a rare case and all substitutes have different................ and if your bd370 is mounted on a heat sink you will have to isolate the new ones (mica or silicone)......... what is the application you need them? greetings............... |
#3 | |
try Cricklewood Electronics Cricklewood They have some BD370C which will do (its a slightly higher voltage version) should be a straight swap |
#4 |
Thanks Team, ordered the parts from Crickle.....
| Looking for replacement transistor | kockaboy | Parts | 4 | 15th October 2008 04:51 PM |
| transistor replacement | xcicc | Solid State | 0 | 16th August 2008 10:05 AM |
| Transistor Replacement | portlandlay | Solid State | 26 | 14th December 2005 07:46 PM |
| Transistor replacement | Mlaen | Solid State | 3 | 18th February 2005 11:00 AM |
| Page generated in 0.07079 seconds (68.85% PHP - 31.15% MySQL) with 10 queries |
