Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th June 2009, 09:44 PM   #1
Default cap replacement, upgrade
hi all
i read an article on cap replacement that recommended replacing all caps with polypropylenes (http://web.archive.org/web/200308071...ckcap.htm#more) does this mean i can replace polarized electrolytics with non-polarized polypropylenes? is that article a little dated? finally, any good sources, especially smd types. my usual soursces don't seem to have to great a selection in that type. thanks
Old 10th June 2009, 04:03 AM   #2
amc184 is offline amc184  New Zealand
amc184's Avatar
This article is about signal path capacitors. The article might be a little dated, but it's conclusions are still valid.
Replacing signal path electrolytic caps with similar film caps is a good idea, but it won't always be practical. Compare the size of a 10uF film cap to a 10uF electrolytic cap!
The generally accepted audio hierarchy for signal path caps is (from best to worst):
- Teflon
- Polystyrene
- Polycarbonate
- Polypropylene
- Polyester
- Electrolytic
- Tantalum
And within the film types, you'll get better performance out of film and foil types, over metalised film types.
Note that this is all a generalisation, there are many things to consider. Best advice is to look at what other people are using!
Good places to fine these caps is eBay, Parts Connexion, Percy Audio and the heaps of other online audio components stores.
2SA1102 and 2SC2577 Upgrade / Replacement chipinnc Solid State 4 17th December 2011 02:18 PM
41Hz AMP2 upgrade... What parts to upgrade? MotoMan_Yz400 Class D 2 6th March 2008 06:28 AM
Muse Model 2 DAC upgrade with Guido Tent DAC upgrade? jpchleapas Digital Source 1 31st January 2008 08:18 PM
the best upgrade there is Daniel-A Everything Else 0 27th March 2004 05:40 AM
Cost Effective Upgrade Replacement For AD817? fastcat95 Solid State 3 8th August 2003 07:58 PM
Page generated in 0.06473 seconds (78.19% PHP - 21.81% MySQL) with 10 queries
