| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am not sure if this is the right place to post this but what is the need for the four and five-pin electrolytic capacitors over a two-pin snap in type...apart from the obvious. What are they used for and can they be used in a circuit where there were previously two-pin snap-in types????
Could I someone give me practical examples of where these multi-pin types are used?? Cheers in advance |
#2 |
Hi
two reasons 1) Mounting stability ie used for larger case sizes generally 2) Special four terminal caps with input/output are used when esl/esr is a concern esp. on SMPS applications. (IMO more rare)
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#3 |
So I can''t use them in a standard transformer/rectifier,reservoir cap sort of power supply??
Cheers Gareth |
#4 | |
For that... smoke'm if you've got em. Just make sure what terminal is what ...single connections are ok.
#5 |
Cheers infinia,
So could I use one of these instead of two two-pin snap-in type electrolytics. I ask this because I am having trouble finding two 63v 15,000uF reservoir caps in my NAD C326 BEE. The ones in there are quite slim in design and I was hoping that i could get away with using one of the multi pin types instead. Any suggestions????? Gareth |
#6 |
Gareth
Most mult-pin snap-in caps are just a single cap, so you still need two. To make sure... find the data sheet. You also could use an analog ohm meter to check as well.
#7 |
Aaaah, OK. Cheers
Gareth |
#8 | |
#9 |
Thanks guys,
The diameter of the original caps is approximately 33mm. They seem to be quite slim in relation to their capacitiance. There are two of them right next to each other and with only a couple of mil surrounding them to 'play-with'. Maybe i should get a photo of them in-situ. I would like to upgrade them, they are made by a company called KSC |
| what is the difference between silver mica capacitors and ceramic capacitors ?? | prorms | Solid State | 1 | 6th May 2008 12:38 PM |
| Multi purpose multi channel gainclone PCB: Team project - group buy | rick57 | Chip Amps | 14 | 29th March 2003 05:54 PM |
| capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors | costiss | Parts | 11 | 30th January 2003 09:32 PM |
| differences between computer grade capacitors and small can capacitors | LBHajdu | Pass Labs | 0 | 22nd February 2002 01:29 AM |
| Page generated in 0.09355 seconds (78.42% PHP - 21.58% MySQL) with 10 queries |
