| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I was calibrating the record and play levels on my Akai 4000DS mk II Reel to Reel tape recorder, and I accidentally shorted something out and fried at least one of the transistors! I need to find some replacements, but don't know where to go, can anyone help? I don't yet know witch ones are fried, but if I replace them all I know I'll get it working again.
these are the transistors I need: C1312 C458 C1647 It's quite an old machine, from 1972, so I don't know if those particular transistors are still in production. Can anyone tell me where I can get them? Or where I could get suitable substitute replacements? I've added a picture to help identify them. |
#2 |
You can find the datasheets by referring them as 2SC1312, 2SC1647 and 2SC458, respectively. The leading 2S is just not printed on the body. I think they are all small-signal, small-voltage NPN transistors, and you can replace them with 2N2369 or BCY58 or the like if you identified the pinout.
Before replacing them, I'd measure them for short-circuit or even better for h21e using a DMM that is capable of such measurement. As a simple test, the B-E and B-C should behave as a diode, the C-E should be open circuit, measure with a DMM in 2kohm range. Test them off-circuit. |
| Replacement platter for reel-to-reel recorder? | jacques54 | Analogue Source | 12 | 21st November 2011 02:32 PM |
| Reel-to-reel tape decks | mellowPH | Swap Meet | 0 | 22nd April 2008 08:00 AM |
| Reel-to-reel tape decks | GK | Everything Else | 12 | 28th March 2008 09:56 PM |
| Paper based reel to reel tape dates | Zero Cool | Everything Else | 1 | 13th May 2007 12:54 AM |
| Reel to Reel Tape, 10.5" | richardsymes | Analogue Source | 6 | 4th April 2005 02:52 PM |
| Page generated in 0.06165 seconds (69.54% PHP - 30.46% MySQL) with 11 queries |
