| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Since this a very active DIY Audio forum I would expect that here is a few guys winding their own transformers.
I would like to pose a few questions: Any tips for a new-bee transformer winder? What can I use to build my own winding jig? What parts are essential? What external tools are also required? The reason for this is that here in S Africa the price of proper audio transformers are incredible and there is no real place here that specializes in audio transformer winding. Market is too small I guess. |
#2 |
Yes, a few of us do actually ![]() Here's my sloppy jig: http://geek.scorpiorising.ca/GeeK_Zo...p?topic=3476.0 Though I now use a magnet on the wheel and a Hall-effect sensor for the counter. All you need is something that turns at a controlled rate hooked up to something that counts and voila! Instant roller. Cheers! |
#3 |
I do occasional big (=lots of turns) ones on my metal turning lathe. I made a simple counter from an ICM7217 which can switch the motor off at a preset count. A photodiode "watches" a paint dot on the belt pulley.
Small coils - few enought turns to count in the head - I do on a old fashioned hand-drill, held in a vice. |
#4 |
Thanks for the replies so far. It seems that there is no magical mysteries to winding transformers.
I saw on the RS Components site that a simple inductance meter can be bought for under $200. |
#5 |
I use a shuttle to wind toroids -- it's a small piece of thin wood, notched at each end.
When I am checking out a transformer I use a signal generator to send a 5kHz signal in one end and measure the ratio of input/output. I've wound quite a few SMPS transformers this way -- with mystery cores -- life is simpler if you purchase cores from Amidon because you don't have to cut and measure -- works right the first time from the equations given, and you know how much heat it will take. |
#6 |
I should probably as if there is any literature on winding techniques of audio transformers that would be a good supplement.
I studied the Hashimoto Electric Co. website with great care trying to absorb the "greatness" of their products - he-he!! |
#7 |
Here's some necessary math from our member mcs:
http://stiftsbogtrykkeriet.dk/~mcs/Transformer.html Pat Turner of Turner Audio has some super info here (scroll down): http://www.turneraudio.com.au/education+diy.htm I have a couple of pages here: http://geek.scorpiorising.ca/windingtransformers.html http://geek.scorpiorising.ca/windingchokes.html Cheers! |
#8 |
Geek! Thank you for all the info. I am now reading your tutorial and it is great!
One thing I need to jog down somewhere is how to calculate the total number of windings and wire thicknesses. |
#9 |
If Pat Turner had a coffee machine in his basement, his wife would never see him.
#10 |
I would like to wind a custom audio transformer. The following are the requirement parameters: > Transformer Type: Audio > Primary Impedance: 200ohm > Secondary Impedance: 10kohm > Turns Ratio: 1:1 How to compute the primary and secondary turns by knowing only the primary and secondary impedances ? I used the formula Xs/Xp and obtained the value as 500. Please confirm. Best regards, Bins. |
| Transformer Winding | microsim444 | Power Supplies | 4 | 3rd February 2009 09:58 PM |
| transformer winding | gearheadgene | Power Supplies | 3 | 14th November 2008 02:52 PM |
| Winding a Transformer | punchpeanut | Solid State | 8 | 1st December 2003 02:48 PM |
| Winding 1:100 Transformer for ESL ??? | kristijan-k | Everything Else | 0 | 26th March 2002 11:08 AM |
| Winding 1:100 Transformer for ESL ??? | kristijan-k | Planars & Exotics | 0 | 26th March 2002 11:04 AM |
