diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   New 'lytics blow the fuse (http://www.diyaudio.com/forums/parts/145030-new-lytics-blow-fuse.html)
glorocks 30th May 2009 02:37 PM
I just replaced the filter caps in a tube crossover, and it now take the fuse out on power up. (yes, I put 'em in correctly)
I suspect the new caps have a much lower initial impedance and the inrush current is too much. I'm using Cornell-Dublier, and the values and voltages are correct.
Anyone out there have any suggestions?
head_spaz 30th May 2009 04:57 PM
yup
If they are the same value as the originals, and installed properly - polarity wise - then you're probably right in assuming they are drawing more charge current.
You could try using a small wattage light bulb in series with the AC line to see if current limiting helps.
If so, you can build a soft start ciruit, or simply add a thermistor in the AC line, which is what I do. I get mine from old PC power supplies.
glorocks 30th May 2009 05:39 PM
Thanks- I hadn't thought about the light bulb, but it makes sense. I''l give it a try in a few minutes. If that doesn't work, I'll try to track down a variac.
So, I'm wondering if perhaps the lytics need to be "formed" on their first power up and will behave on subsequent power ups?
454Casull 31st May 2009 09:33 PM
Is the capacitance higher in the new caps?
glorocks 1st June 2009 05:07 PM
No- same value and voltage. The new caps are considerably smaller than the originals, but they read the correct capacity on a cap tester.
I rigged a supply to output the rated B+ (450 vdc) and hooked it up to a variac I borrowed. I'm raising the voltage 5 volts or so every couple of hours until I get to +450. Hopefully, that will form the caps and they'll behave after this treatment.
If you guys have and old HAM radio enthusiast in your neighborhood, get to know him. They know a LOT of tube and HV tricks.
MCampbell 3rd June 2009 10:11 AM
By raising the voltage so slowly to the rating voltage of 450V, I believe that you are in effect forming the capacitor at each of the lower voltage(s). This may affect the performance of the capacitor. It's better to go straight in at the rated voltage and keep an eye on the leakage current over time. Once it steadies out, the cap is properly formed.
See this link for good general outline:
http://www.vcomp.co.uk/tech_tips/ref...eform_caps.htm
AndrewT 3rd June 2009 11:04 AM
presumably the mains transformer is an EI. This should not need a soft start but a small benefit will accrue if you choose to use one.
The slow charge circuit can be a Power Thermistor in the secondary circuit to limit the peak charging current. This will be very beneficial. Fit it.
A light bulb will not do, it is PTC, you need NTC.
AndrewT 3rd June 2009 11:09 AM
the high series resistance ensures that the capacitor is initially charged by a very low voltage and as the capacitor leakage reduces so the charge across the plates increases.
It is wrong to suggest that staged charging is less effective than gradually increasing charging.
Ultimately the di-electric film will be the same thickness and it will suit the final voltage.
I use much higher resistor values to achieve much slower re-forming.
MCampbell 3rd June 2009 11:26 AM
Andrew,
You may well be right that ultimately the dielectric layer will be the same thickness. What I am struggling with is the advantage of staging the voltage or of slow reforming. Certainly I have never seen it recommended by any manufacturer. Has your experience been that sow reaging will ultimately lead to a lower leakage current for the reaged capacitor. Or is there some other benefit that I'm missing?
Matthew
AndrewT 3rd June 2009 12:05 PM
I find leakage currents after slow re-forming between ten times and one thousand times lower than specification.
I asked for comment a while back, but got no replies.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
