New 'lytics blow the fuse - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd June 2009, 01:41 PM   #11
Originally posted by AndrewT
I find leakage currents after slow re-forming between ten times and one thousand times lower than specification.
I asked for comment a while back, but got no replies.
Andrew,
I do a fair bit of reforming, so I'm very interested in your finding.
I use a GR-1617A Capacitance Bridge for reforming (mainly because it only cost me about 50) which does a fine job, and should allow me to stage to voltage.
I'm certainly going to give this a try. I'll dig out an old pair of 500V lytics and try reforming one at 500V only and the other stagewise up to 500V.
To get the results you've indicated, what increment and period have you used? Are we talking 5V increase per hour?
Old 3rd June 2009, 02:40 PM   #12
http://www.diyaudio.com/forums/showt...086#post940086
http://www.diyaudio.com/forums/showt...798#post968798
http://www.diyaudio.com/forums/showt...545#post969545
might give some clues to where I come from.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 4th June 2009, 01:36 AM   #13
OK- I raised the voltage to the +450 rating over a period of about 4 hours, bringing the voltage up 10 or so volts every 15 minutes, or when I remembered to do it.
One cap came up nicely, and when put back in the circuit worked as expected.
The second cap, although measured at the correct capacity on my cap tester, (low voltage), blew up when I got to around 100 volts. No fuse on the test rig to get in the way of catastrophy.
So it appears the second cap was the problem and was defective from the vendor. Haven't seen this before, but life is full of suprises.
Thank you all for your help and insight- all of which was most illuminating-
Old 4th June 2009, 03:54 AM   #14
unclejed613's Avatar
i work at a company that does a lot of repair work. we recently got some caps in our "bench stock" that had one particular value (47uf/100V) that we use often, with about half of the batch mismarked for polarity. i think the clue (other than one tech blowing one up) was that the uncut leads had one long one(+) and one short one(-), with the shrink-on label reversed (i.e. the long lead was on the same side as the (-) stripe).
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Sa-5.1 blow fuse jpweaner2 Tubes / Valves 0 3rd May 2007 02:36 PM
Soundstream SA 245 - Blow Fuse babygot Car Audio 4 7th January 2005 06:06 PM
Two power supplies blow fuse h_andree Chip Amps 14 4th September 2004 03:09 AM
Fried a slow blow 4 A fuse chris ma Everything Else 2 10th October 2003 07:59 AM
Tube amp fuse blow out Gabevee Tubes / Valves 1 4th March 2002 04:55 PM
Copyright 1999-2017 diyAudio
