Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th May 2009, 12:03 PM   #1
Default Nichicon Conductive Polymer Caps
Does anyone have experience with modding with these Nichicon LF series caps? If you look at the pics of the inside guts of some high end amps, they appear to have these in them. Look at your Audio Advisor catalog for an example. See attached.
Are they good or bad?
Thanks, Tom
Old 4th June 2009, 03:32 PM   #2
pdul is offline pdul  Denmark
From what i have read, it is very similar to OS-CON`s. Good for local decoupling in rails (low esr, good for high frequence)
Old 10th June 2009, 03:54 AM   #3
amc184 is offline amc184  New Zealand
amc184's Avatar
I've used a few of the very similar Nippon Chemicon PSA series for decoupling digital ICs. They're solid polymer caps, great for decoupling digital stuff as the have a low ESR even at high frequencies.
I can't say I'd use them in an amplifier though, regular low impedance electrolytics seem more appropriate. Unless it's a Class D amp I suppose.
Old 10th June 2009, 01:19 PM   #4
I have used OS-CON`s as local decoupling in a preamp with very good result
Black Gates out, conductive polymer in... sharpi31 Parts 14 22nd February 2009 12:11 AM
Conductive Polymer capacitors : oscons replacements! NeoY2k Parts 2 22nd September 2008 09:45 PM
Where can i get nichicon FW series caps? FlyYoung Parts 3 5th May 2007 05:09 PM
NICHICON ST (Super Through) CAPS Dominick22 Chip Amps 4 10th March 2006 04:21 PM
Polymer Aluminum (AlO) Caps tiroth Parts 0 17th May 2002 01:45 PM
Page generated in 0.06411 seconds (82.89% PHP - 17.11% MySQL) with 11 queries
