Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Capacitor tolerance
Capacitor tolerance
Old 24th May 2009, 04:50 AM   #1
boxerboxer is offline boxerboxer  United States
Default Capacitor tolerance
I'm working on the steve bench phono pre circuit and am trying to figure out sourcing for the riaa network caps. The values to go for according to salas are 6500pf (1800||4700) and 11400 pf (1000||2200||8200). What I'm wondering is, how tight do the tolerances need to be for these. I found them on mouser.com in silver mica 1% (except the 8200pf which is non-stocked - 2% is in stock). However, it would be over 50 bucks just for those caps, so I'm wondering if I can go wider on the tolerance and/or find a better deal elsewhere.
Ben
Old 24th May 2009, 05:38 AM   #2
sawreyrw is offline sawreyrw  United States
I'm not an expert on this, but I think it is OK to go with +/- 20% parts. They should be a lot less expensive.
Old 24th May 2009, 07:55 AM   #3
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
For RIAA you need the closest tolerance parts you can get. RIAA is incredibly sensitive to errors because you are trying to cancel out one steep curve with another to get a flat response. 2% tolerance is not good enough. Try looking for polystyrene instead of silvered mica.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 24th May 2009, 08:50 AM   #4
454Casull is offline 454Casull  Canada
Might be cheaper to invest in a good LC/LCR meter and get a bunch of high-tolerance caps.
Old 24th May 2009, 11:03 AM   #5
Geek is offline Geek
Geek's Avatar
IMO, 2% is just fine.
I have measured tubes drifting spec. over their lifetime more than that, making any cap tighter than 2%, moot.
Now a SS RIAA, yeah, go with 0.5% or whatever you can afford.
Cheers!
Old 24th May 2009, 02:50 PM   #6
Cheers!
Right, if I didn't need 500V caps this would be a whole lot easier.
Old 24th May 2009, 03:53 PM   #7
Where do you suggest looking for these? Searching mouser, allied, and digikey failed to yield anything in 1% tolerance at the voltage spec I need.
Old 24th May 2009, 04:11 PM   #8
DaveInVA is offline DaveInVA
As someone else mentioned get a LC/LCR meter and hand pick your own. I feel its as if not more important for the caps and resistors in each channel to match each other so you don't notice a difference in tonal balance between channels. ie; if one cap is at one end of its 10% tolerance in one channel and the same cap in the other channel is at the other end of its 10% tolerance you will likely hear it..
Dave
Old 24th May 2009, 05:43 PM   #9
On Hiatus
SY's Avatar
Capacitor tolerance
There's two schools of thought on RIAA accuracy. One is, "make each channel be as tight to RIAA as possible." The latter is, "absolutel conformance is nice but channel-to-channel matching is most important." My own views tilt toward the latter. I want each side matched to better than 0.1dB.
You can use an LCR meter, but a better way (considering tube and stray tolerances) is an inverse network (same network used in both channels' measurements) fed from a very flat generator or flat input and accurate AC voltmeter measurement of the output. Undersize the caps a bit, then trim to spec with smaller caps.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 24th May 2009, 07:57 PM   #10
Geek's Avatar
A trick for that is have a larger value DC blocking capacitor (0.1uF to 0.47uF @ 630V is easier to find than RIAA valued ones) in series with your accurate cap. 50V is fine for the accurate cap because there's no way any AC value in an RIAA stage will (or should) exceed the RMS rating.
Cheers!
Capacitor toleranceHide this!Advertise here!
RN65C / E 10KB - what tolerance ? Bernhard Parts 1 21st April 2007 09:10 PM
WTB: 2x 3mh 20AWG inductors, 20% tolerance owdi Swap Meet 2 28th July 2005 05:50 AM
900% Vas tolerance? Otter Subwoofers 1 10th May 2005 12:16 AM
0.01% tolerance 10 and 100 ohm resistors SkinnyBoy Swap Meet 2 26th November 2003 10:38 AM
1% tolerance resistor spreadsheet MRehorst Parts 1 16th December 2002 03:38 PM
