Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd May 2009, 04:21 PM   #1
Question DIY step down transformer
Hi Guys,
I'm trying to diy a step down transformer to operate a 110V brad nailer from my 230V wall source.
Is it just a matter of getting a toroidal core, and winding a 2:1 primary to secondary coil ratio?
I did that, and when i tried plugging it into the wall socket, well the fuse tripped. This was with the secondary winding open circuit - i was planning to measure it using a multimeter to make sure i got the number of coils and hence voltage ratio correct.
This got me thinking, with no load on the secondary winding, how is the current in the primary winding controlled? I'm thinking it has to do with the inductance, or complex resistance, which prevents the primary winding from drawing too much current? How does a load on the secondary winding affect this? By reducing the inductance, and hence increasing the current in the primary winding?
This would be the load on the brad nailer, which only draws current when fired. Otherwise it would be open circuit...
Does that mean i have too low an inductance on my primary winding, hence it is drawing too much current and tripping the fuse?
Sorry if i am going in circles. I think i need some help here. The stuff i found online about transformers seem rather generic, nobody mentioned anything about fuses tripping when you connect the primary winding to the mains source...
Thanks a lo!!!
Old 23rd May 2009, 04:29 PM   #2
it's a case of buying a 220/240Vac:55+55Vac transformer.
Wire the two secondaries in series for your 110Vac feed to the nailer.
regards Andrew T.
Old 23rd May 2009, 04:49 PM   #3
Andrew,
Thanks for your reply. I already have a toroid core, and some wires lying around, so i was trying to make it work. Does the absolute number of coils matter?
Thanks!
Old 23rd May 2009, 05:02 PM   #4
SY's Avatar
May I be perfectly honest with you? These are all excellent questions you're asking and I'm glad to see you asking them. Primary inductance for the frequency and load is a vital consideration.
But the fact that you're asking these excellent questions would make me STRONGLY advise you not to try winding your own mains-based high power transformer from scratch until you get more experience. This is a serious safety issue. Buy a stepdown transformer or do as Andrew suggests.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 24th May 2009, 03:16 AM   #5
Thanks for the advice and clarifications.
Alternative step-up Transformer? enilsen Planars & Exotics 8 12th November 2006 09:56 PM
Step Down Transformer Ropie Power Supplies 3 15th October 2006 09:42 AM
Can I use a step-up transformer as step-up? cviller Parts 5 6th September 2006 06:32 PM
EI core transformer for step-up PSU Solid Snake Solid State 7 9th December 2003 04:29 PM
Using one transformer to step down another. Shoog Solid State 9 28th August 2003 10:00 PM
Page generated in 0.08177 seconds (79.20% PHP - 20.80% MySQL) with 10 queries
