Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th May 2009, 04:05 PM   #1
Default Mystery Component
This is from a tube based power supply and feeds the cathode of a 6H30 from the positive rail. It says 583 KS on it. Is it a 58v zener?
John
Old 18th May 2009, 04:18 PM   #2
are you referring to the device with the translucent case?
What voltage is across it?
regards Andrew T.
Old 18th May 2009, 05:45 PM   #3
Sorry, for the confusion. Yes it is the translucent device. I was not able to measure the voltage across it.
John
Old 18th May 2009, 07:08 PM   #4
analog_sa's Avatar
More details? Or at least a larger pic? Is it an ARC component?
Old 18th May 2009, 09:45 PM   #5
Yes this a Ref 3. I got a chance to take a careful look at a friends and want to see if I can clone it. I'll see if I can put up a better picture.
John
Old 18th May 2009, 09:54 PM   #6
analog_sa's Avatar
It's about the only ARC pre worth cloning IMO. A very quick preliminary question what does it use for volume?
Old 19th May 2009, 04:40 AM   #7
Tube_Dude's Avatar
Default Re: Mystery Component
John
Its a 58 nF polystyrene capacitor...
Jorge
Old 19th May 2009, 12:44 PM   #8
Tube Dude, thanks. I just did not think of polystyrene as a possibility. Do I need to use a polystyrene there? Or can I use something else?
The volume is controlled by chip resistors just like all ARC's over the last couple of years.
Old 19th May 2009, 12:55 PM   #9
Tube_Dude's Avatar
Tube Dude, thanks. I just did not think it of polystyrene. Do I need to use a polystyrene there? Or can I use something else?
Is better to stay with polystyrene, because de low losses and precision.
http://www.jaycar.com.au/images_uploaded/rescode.pdf
Jorge
Old 19th May 2009, 01:15 PM   #10
Tube_Dude's Avatar
Why you think the capacitor is to blame?
They usually stand for a life time...
Jorge
Mystery RF amp spooney Car Audio 11 25th April 2008 06:14 PM
Oscilloscope mystery herrdahlin Parts 6 6th January 2008 04:23 PM
little 6.5 mystery ... oface Full Range 6 4th November 2007 11:20 PM
Mystery SE OPT alexmoose Tubes / Valves 4 11th July 2006 01:29 AM
mystery... mista2 Multi-Way 1 14th January 2005 04:20 AM
Page generated in 0.08611 seconds (80.39% PHP - 19.61% MySQL) with 11 queries
