Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th May 2009, 05:33 PM   #1
Mark245 is offline Mark245  United States
Default Heatsinks
I have a question about mounting output transistors on a heatsink. First of all, is aluminum a good choice or is there a better material? Also, for TIP31/32 transistors, the collector is the metal part that will be mounted to the heat sink. Could this create a problem? The collectors for the TIP 31's should be at a different voltage than that of the TIP32's.
Old 14th May 2009, 05:49 PM   #2
h_a is offline h_a  Europe
h_a's Avatar
Yes! And the only affordable one ;-)
Copper, Silver!
Boom! in case anodizing is not perfect.
For this reason good people invented insulating heatpads.
Have fun, Hannes
Old 14th May 2009, 05:56 PM   #3
Oh ok thanks. That actually makes me wonder, why is that metal part used for mounting attached to the collector? There is already a pin for it.
Old 14th May 2009, 06:23 PM   #4
Hurtig is offline Hurtig  Denmark
Because the power (heat) is dissipated in the collector of the transistor. In order transport the heat away from the silicon, the collector is connected directly to the collector.
Old 14th May 2009, 06:35 PM   #5
Ok that makes sense now thanks for the help.
Old 15th May 2009, 10:42 AM   #6
jitter is offline jitter  Netherlands
jitter's Avatar
Don't forget the insulation ring between screw and case.
Old 18th May 2009, 01:11 AM   #7
Minion is offline Minion  Canada
and use a Multimeter to make sure the Transistors are actully isolated from the heatsink .....
To-3 Heatsinks sandstorm33 Swap Meet 8 6th February 2008 04:33 PM
about heatsinks bigpanda Solid State 2 4th May 2005 03:34 PM
Heatsinks DD_Davo Chip Amps 2 13th April 2005 01:00 PM
Heatsinks Peter Daniel Swap Meet 19 3rd February 2004 11:08 PM
Heatsinks for DoZ ultrachrome Solid State 0 4th February 2003 09:23 PM
Page generated in 0.08252 seconds (75.65% PHP - 24.35% MySQL) with 10 queries
