Go Back   Home > Forums > Design & Build > Parts
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 12th May 2009, 09:35 PM   #1
weinstro's Avatar
Default Making a bipolar cap
I need to make a bipolar electrolytic capacitor by series connecting two normal, polarized electrolytic capacitors. Does it make any difference if the caps are connected "-" to "-" or "+" to "+"?
Thanks-
Rob
Old 13th May 2009, 05:11 AM   #2
jcx is offline jcx
if you're using it for audio coupling then buying a real bi/non-polar is much the better option from measured distortion
Old 13th May 2009, 06:58 AM   #3
weinstro's Avatar
I tried, but it's not feasible for this app, a dc blocker for a torroid transformer.
Rob
Old 13th May 2009, 08:16 AM   #4
mjf is offline mjf
hello.
i think usually the - poles are connected together.have a look at the schematics symbol, the +pole is outside........
i would use high voltage ratings as possible for safety.
greetings...........
Old 13th May 2009, 08:22 AM   #5
Draw the circuit with the two caps in series, an AC source and a load.
You will then see that the caps can be connected either way round - it cannot make a differnce.
Old 13th May 2009, 08:31 AM   #6
Mooly is offline Mooly
Mooly's Avatar
Plus to Plus or neg to neg, but can be worthwhile (if feasable) adding two very high value resistors say 100K to 1meg range of equal value across each to make sure 50/50 volt drop.
Old 13th May 2009, 03:31 PM   #7
weinstro's Avatar
Thanks - A diode string (bridge rectifier, 35 amp) will be in parallel to limit voltage drop to aprox 1.4 volts.
This is an adaptation of a DC blocking circuit used by Bryston. There are several threads on this topic, which I cannot easily provide the link to from the device I'm using to reply to this thread.
I'm only trying to establish if there is any performance or other based reasoning to connect the caps by their "-" or "+" leads.
Rob
Old 13th May 2009, 03:35 PM   #8
weinstro's Avatar
Originally posted by mjf
hello.
Guys, thanks for getting right to the heart of the question - it does / does not matter.
I think I'll connect them "-" to "-". Thanks!
Rob
Thread Tools
Opamp?? FET vs Bipolar evo9 Chip Amps 8 18th May 2008 07:47 AM
Using bipolar opamps speakerguy79 Solid State 2 16th March 2007 04:48 PM
A way to get rid of bipolar zero error AD1865 Digital Source 24 22nd October 2004 01:30 AM
Bipolar PSU capacitor Prune Parts 2 26th July 2004 06:31 PM
How does this bipolar look? punchpeanut Solid State 11 2nd October 2003 08:48 AM
Page generated in 0.15580511 seconds (80.50% PHP - 19.50% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
