| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Could someone please tell me what brand my Volume Pots are in my preamp?
Also, what upgrade would you suggest in these? Center to center between the left and right volume knobs is 1.80", so I would need something that would fit, a Shallco definitely will not fit here... Rick |
#2 |
Here is a complete picture of the inside of my preamp...
#3 |
Can you unmount one? There should be a logo or something on them somewhere Cheers! |
#4 | |
Yes, that is the obvious way to find out, but I have already put it back together, hooked everything up and I would have to desolder/resolder some wires... I was hoping someone here might be able to identify them by sight, so I don't have to do that... Rick |
#5 |
OK, until someone comes along, lets use what info we have....
That white... is that ceramic or plastic? If it's a cermet pot, an upgrade to something "better" would be pretty pricey. If plastic, an Alpha would be an upgrade Cheers! |
#6 |
If it helps, the preamp is a VAC CPA-1 MKIII
#7 |
Ok, thanks
From what I've Googled, they are quality preamps and would likely be cermet. Are they scratchy? Cheers! |
#8 | |
| How to ID volume & fader pots? | jol50 | Car Audio | 54 | 18th January 2008 05:26 AM |
| volume pots for tube amp | Miller-8 | Parts | 5 | 16th February 2007 04:29 PM |
| Volume pots: Why are low values better? | Christer | Parts | 11 | 9th January 2006 10:41 PM |
| 1 remote for 2 mono volume pots? | snowbubba | Everything Else | 0 | 21st April 2005 09:38 PM |
| Best Volume Pots? | A3rd.Zero | Parts | 18 | 2nd May 2004 04:00 PM |
| Page generated in 0.08334 seconds (77.50% PHP - 22.50% MySQL) with 11 queries |
