Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th May 2009, 02:55 PM   #1
theAnonymous1's Avatar
Default Compact signal coupling caps - the lesser evil?
As we all know, "good" signal coupling caps tend to be large..... very large. Which of the below caps would be considered to be the best of this bad bunch? I know this is a subjective topic, but I don't want this to turn into another big cap debate (I know, odd request considering the topic).
SMD X7R
SMD Tantalum
Electrolytic (Like Panasonic FC/FM, not exotics like balckgate)
Sanyo OSCON
WIMA MKS (PET)
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 9th May 2009, 03:06 PM   #2
jcx is offline jcx  United States
Cyril Batemann measured distortion in "capacitor Sound" articles - for big C his recommendation is non-polar Al electrolytic with generous V rating 35 V+ for signal levels, 2 such Caps in series were better for signals larger than a few V
the former audiophile recommendation of biased series polar caps didn't measure as well
all film caps measured better than the best electrolytic
other considerations might include the physical size - a large loop formed by soup can sized audiophile caps could easliy form better attennas for EMI
any DC bias turns a Cap into a microphone - again audiophile wound film/foil caps could be worse on this charateristic
Old 9th May 2009, 03:28 PM   #3
OK, so as the the kids would say.... PET FTW!
Old 9th May 2009, 03:32 PM   #4
yet another consideration is that any Cap distortion would be expected to be porportional to the signal Vdrop across it - "super sizing" with Al electro may still be competive sound-wise if it can be hugely larger in value in the same space
Old 9th May 2009, 09:59 PM   #5
grenert is offline grenert  United States
If going surface mount, I'd suggest Panasonic ECP-U (available from Digikey) or Cornell Dubilier FCA (available from Mouser). I know they go up to at least 1.0 uF. I've used these in portable devices to good effect. FWIW, my ears find MKS disagreeable in a signal coupling function. Don't forget about Elna Silmic II. These are cheap and available in big uF sizes. They're among my favorites for headphone coupling.
Old 9th May 2009, 11:07 PM   #6
Thanks for the heads-up on the Panasonic ECP-U. They are relatively cheap and would still have a compact profile even if stacked two or three high.
Budget electrolytic cap for signal coupling 100db Digital Line Level 7 5th February 2009 01:39 PM
Evil Experiments - Hammond Paper in Oil Caps korneluk Tubes / Valves 8 6th January 2009 02:50 PM
Op Amp chips in the signal path - evil or not evil ? thylantyr Solid State 19 25th July 2008 05:43 PM
XA60.5 - Is there a coupling cap in the signal path ? Blitz Pass Labs 3 20th April 2008 09:55 PM
X2 MKP mains cap for signal coupling DECKY999 Parts 3 11th March 2008 12:03 PM
Page generated in 0.07828 seconds (75.41% PHP - 24.59% MySQL) with 10 queries
