Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Ming Da transformer problem?
Old 7th May 2009, 02:52 PM   #1
RobWilJr is offline RobWilJr  United States
Default Ming Da transformer problem?
I'm assuming for those of us Ming Da amplifier owners who have lost a power transformer (or are in the process of losing one) that we are S-O-L.
I've got a Ming Da MC-88C that recently blew a fuse. I found a fried screen grid resistor and replaced all of them while I was at it, and replaced the power tubes with a new matched quad, biased them to .41V and thought I was back in business. But evidently that wasn't the extent of the damage because the power transformer is seriously over-heating under load. It still plays and sounds great but after around 30-40 minutes the power transformer gets hot enough to burn you (I've only tested this once since I noticed it). Being able to replace known bad parts, and take measurements relatively safely, is about the extent of my knowledge. So, considering it still operates and sounds good, does that mean the transformer isn't a lost cause yet (assuming it is the transformer)? Is it possible that there is another problem causing the transformer to overheat, and there isn't even any damage to the transformer yet? I am addicted to the sound of this amp and am afraid to lose it. Any suggestions or comments would be greatly appreciated.
Old 10th May 2009, 04:10 AM   #2
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
you need to check your output tube idle currents. new tubes might be needing to be re-biased. most (not all) newer transformers have a thermal fuse in them. the temp rating of the thermal fuse is usually quite a bit below the melting point of the enamel on the wire. however, you have something drawing current. bad caps in the power supply could cause it, or like i said, your output tubes could be running a bit too much current.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Ming Da transformer problem?Hide this!Advertise here!
Ming Da MC368-B90 ManUtd Tubes / Valves 2 18th October 2012 08:49 AM
Ming Da MC-34B fuse value? cscmc1 Tubes / Valves 1 26th October 2008 08:46 PM
Ming Da MC-7R transformers for Quad 22 clone. johnm Tubes / Valves 0 6th June 2008 07:43 PM
Ming Da MC34B....passive or active pre amp? Paul Dimaline Tubes / Valves 2 29th January 2006 08:35 PM
Transformer problem Semir Power Supplies 3 3rd January 2005 12:36 AM
Copyright ©1999-2017 diyAudio
