| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have built a pre amp switcher using a 3P1T switch. I switched the commons together and the R and L separate. Because the signals from the pre amps are going straight to the poweramp I'm experiencing some "poping" at the moment the switch is thrown. I tried placing 100K resistors to ground on the inputs, inputs and outputs, and just the outputs with no luck.
I used a sealed switch. Do I have to have a make before break switch for this to work?? Where would I source one if I do? Any help would be greatly appreciated. Thanks. |
#2 |
I don't switch the grounds and all the grounds on the RCA inputs and outputs are tied together for my preamps. Then I run only 1 ground wire from the RCA connections to the pot or active stage.
Usually I only use a 2 pole break before make and have no noise issues.
No longer DIY active |
#3 |
Nice work!! I switched the grounds because I was concerned about getting ground loops if either of the outboard preamps are plugged into different outlets.
Also, the signals are going directly into a power amp and not a pre amp. It worked great switching cd players and dvd players into a pre amp. I'm guessing lower gains on the pre didn't amplify the pops like the power amp did. |
#4 |
I always think of the RCAs as sort of a star ground so it all goes back to 1 point. See how it goes.
#5 |
Hey it worked!! I tied all the grounds together and voila!! No more pop.
Thanks for the help! |
#6 |
Cool!
| Bypassing switcher | iUSERTLO72p | Car Audio | 4 | 22nd January 2008 12:12 PM |
| WTB: abx switcher | garlandstephens | Swap Meet | 8 | 2nd December 2006 09:41 PM |
| Amp pops on power down? | jjai | Instruments and Amps | 2 | 8th March 2005 08:26 PM |
| First Gainclone..with a 'switcher' and 'XO' | mpmarino | Chip Amps | 17 | 7th October 2004 01:10 AM |
| Anyone use an offline switcher PS for GC? | speaker | Chip Amps | 4 | 26th March 2004 01:02 PM |
| Page generated in 0.07635 seconds (75.19% PHP - 24.81% MySQL) with 11 queries |
