| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi Guys
I am having a discussion with a friend about my supply for my 2 x pa150 lm3876 amplifier. He says that a coil in the supply will set the responcetime for the supply down so drasticly that it will sound terrible. is that in any way correct? Here is my supply diagram. [IMG]http://img17.imageshack.us/img17/1882/tilh4a.jpg[IMG] The coils is EI iron core, with the E and the I seperated by a thin nonelectric-material. It has a DC resistance at .2Ohm. EDITED the image, it is quite big ...
I am new to this - |
#2 |
first of all, you don't really need the coil, as the PSRR for this device is between 85 and 120db. the inductor's impedance is 300 ohms at 50hz, so it does smooth out a lot of ripple, but with such a high PSRR it's really not necessary.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net spammer trap: http://www1284177414881.v-dc.net/ |
#3 |
Your bridge connections are wrong on your schematic.
#4 |
35mH is way too much, 2mH would do just fine. Air core is to be preferred, as you have no issues of saturation and the like.
For a chip amp, an inductor may be a bit overkill, but not completely pointless. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#5 | |
No, that is not correct. Magura
#6 |
and C1 & C2 will probably fail due to overheating.
regards Andrew T. |
#7 | |
Banned
w Your PSU is mad overkill. Any 4sshole with money can do that. |
#8 | |
you're right, while everybody else was looking at the coils and bizarre arrangement of caps, the biggest, most obvious BOO-BOO of all went unnoticed, not to mention what would happen if he hooked the bridges up correctly......... bridge rectifiers in series is always a bad idea, unless you happen to like fire and smoke.... it would work much better like this if he's using two transformers for the supply
#9 | |||||||
But i got my answer. Thx guys
#10 |
C1 & C2 are 1mF, what is the ripple rating?
The first caps in a CRC or CLC PSU are subjected to a very high ripple and this high ripple causes losses in the esr creating heat. A small electrolytic cap located here cannot have sufficient ripple rating to survive very long. It will overheat and eventually fail. If you connected 10off 1mF in parallel you will have increased the ripple rating by a factor of ten. That is more likely to survive than selecting a 10mF cap.
regards Andrew T. |
| Power supply filter mod | Ty_Bower | Tubes / Valves | 3 | 21st July 2007 01:50 AM |
| B+ supply filter | nhuwar | Power Supplies | 1 | 19th January 2007 10:32 PM |
| Filter/Regulator for B+ Supply | Kashmire | Tubes / Valves | 1 | 26th October 2004 02:50 AM |
| Single supply sub filter | palesha | Solid State | 15 | 4th September 2002 03:28 PM |
| RC supply filter in Class AB amp | tiroth | Solid State | 2 | 19th April 2002 07:44 PM |
| Page generated in 0.12719 seconds (86.33% PHP - 13.67% MySQL) with 11 queries |
