| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm about to throw away an old 15" CTX PC monitor but may salvage it for parts first. I've seen a couple of xformers that I'll probably remove. Are there any parts in particular that I should look for which may be applicable to future diy audio projects?
Thx. UncleJessie |
#2 |
The ferrite core from the line output transformer can be used as the basis of an RF choke. The line output transistor will be a high-voltage device that can be used in an HT regulator. If you're feeling really grungy, the field scan IC is effectively a 3W (or so) audio amplifier. There might be other bits, but I can't think of them at the moment.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#3 |
Monitors often will have good heat-sinks in them and decent high voltage 200-450V caps. The deflection coils are sometimes made with litz-like wire which can be used for making inductors.
I get a lot of dead monitors -- i try to recycle as much of them as possible (ie plastic goes towards making plastic lumber) -- i hate to see them hit the landfills. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
I also have access to many old CRT's that are going to thrown away.
There are many electrolytic caps in them. some high values to. Are these caps good for audio circuits? I also found a lot of caps that are red or blue and have the shape of a cylinder that has been squeezed. There's probably a good english word for this shape, but that's the best way I can describe it They look like they're made of epoxy. What kind are they? and are they any good? Another type I found were rectangular shape caps that had AC voltage ratings (250V). Can I use those? I'm planning on building the P3a, using only recycled parts. I also heared that electrolytic caps get worse over the years. How fast do they get worse? |
#5 |
Polyester, or using the brand name, mylar, caps. Good stuff.
I once pulled a 3.5uF (i.e. marked "355") 200V cap from a monitor. It's in a speaker now. The HV transistors (HOT (Horizontal Output Transistor) might be on a heatsink near the FBT, and you might have one (or a MOSFET) for the switching supply) are good stuff, usually rated for a good couple of amps and a kV or so. The 'lytics in the PSU are usually good on size and voltage. Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#6 | ||||
dave
#7 | |
I've seen some other pics on websites, and they look like mylar caps. Some have the inscription MEF on them. Metal film? The rectangular shaped ones with the high AC voltage ratings have MKT written on them. Difficult to identify all these caps, ofr a beginner like me though. But I'm learning. Are electrolitic caps good enough for SS amps? or are they to unstable? |
#8 | ||
dave
#9 | |
Properly-designed monitors contain good-quality capacitors around the line-scan and PSU department.
#10 | |
dave
| Is this capacitor worth keeping? | cadbury8 | Parts | 15 | 4th July 2007 04:44 PM |
| Bunch of old parts, worth anything? | rkc7 | Tubes / Valves | 29 | 6th January 2006 02:21 PM |
| Personal Monitor sized speakers : are ESL worth the troubles?? | JinMTVT | Planars & Exotics | 17 | 10th September 2004 06:32 AM |
| Any good DIY parts shops in Dallas/Ft Worth? | Hybrid fourdoor | Parts | 1 | 23rd October 2003 12:51 AM |
| Page generated in 0.11665 seconds (81.71% PHP - 18.29% MySQL) with 11 queries |
