| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
The monitors I used to look at were viewed in semi-darkness, so the tubes lasted well, in contrast (sorry) to computer monitors that face windows (oh no, not again, that really wasn't intentional).
I've just remembered. I started electronics by going to the tip outside the rental TV repair shop and cutting components out of (valve) tellys! Didn't know what I was doing, of course. Just went for the bigger brighter colours. (I was only 12.) The tellys were monochrome.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#12 |
I went out and dissassembled one of my favorite monitors so i could take a picture of what is inside -- pic does not include some nice holey aluminum "cages". That i have 4 of these monitors makes some of the parts more useful (ie multiples of the same bits)
elcos only go up to 250, a nice looking hi-voltage film cap (big yellow one, 6.8 uF IIRC), loots of various heatsinks, plastic caps, big power resistors, some silicon (including regulators?), cermet pots, transformer/choke cores, an IEC input with filter & extra steel can for shielding, ferritte rings. The deflection coils (not shown) supply a whole bunch of magnet wire. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#13 |
Date's gotta be 80s at least. They haven't used perforated sheilding for quite some time.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#14 |
only thing i save at the shop is power resisters and fuzes and the odd v ic
#15 | |
dave
#16 |
somthing close to it i think
MJH-16006 450V @ 8A TRANSISTOR Motorola MJH-16006, NPN, 125Watt, TO-218 case transistor, rated 450V BVceo, 6V BVeb, 8A Ic max., DC current Gain=5 @ Ic=8A & Vce=5.0V., For line operated switching supplies, inverters, motor controls, etc. [WT.] .01 http://www.mpja.com/allpict.asp?dept=113 i think its from a power supply MJH 11022 (46102) * Trans.250V 15A 150W |
#17 |
#18 | |
dave
#19 |
It is more likely from a deflection circuit, there aren't usually complementary transistors in the power supplies.
That's a big monitor... small ones usually don't have that much stuff inside |
#20 |
I began to search for recycled parts to build an amp (the p3a).
But it doesn't seem to be as easy as I expected it to be. I tried a few monitors and a vcr, but almost nothing I can use. Many electrolitics, but almost always low voltage ones (16V). When I look at prices in catalogues, it seems a waste of time to search for components, since caps and resistors are almost free. The very high quality ones aren't cheap, but you'll never find those in old equipement. unless you find a few broken Krell amps, but the chances of that happening are pretty low Am I looking in the wrong places? |
| Is this capacitor worth keeping? | cadbury8 | Parts | 15 | 4th July 2007 04:44 PM |
| Bunch of old parts, worth anything? | rkc7 | Tubes / Valves | 29 | 6th January 2006 02:21 PM |
| Personal Monitor sized speakers : are ESL worth the troubles?? | JinMTVT | Planars & Exotics | 17 | 10th September 2004 06:32 AM |
| Any good DIY parts shops in Dallas/Ft Worth? | Hybrid fourdoor | Parts | 1 | 23rd October 2003 12:51 AM |
| Page generated in 0.11511 seconds (76.02% PHP - 23.98% MySQL) with 11 queries |
