Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th April 2009, 09:52 PM   #1
glt is offline glt  United States
Default Need help lifting pin
Very little experience with SOIC (only soldered a couple of PGA2320 so far). I need to lift pin 3 of the WM8804 in a Twistedpearaudio receiver board in order to use the chip in S/W mode. It is currently connected to the GND plane.
What is the best way to do this?
Thanks in advance
Old 19th April 2009, 10:37 PM   #2
unclejed613's Avatar
i use a tiny hook made from a small spring. the hook is small enough to hook just one pin of an SOIC. the rest of the spring is straightened out and mounted with tape to a desoldering probe to facilitate a handle. i insert the hook between the pin i want to lift and the one next to it and then rotate the hook to grab the pin i want to lift. then i heat up the solder and pop the pin off the pad. be careful, as some of these pins can be brittle and easily broken
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 19th April 2009, 11:12 PM   #3
Very nice, thanks. Spring wire hook is a great idea.
Old 23rd April 2009, 09:51 PM   #4
did you lift the pin yet?
The spring is a very good way if you have enough space between pins. I spend alot of time soldering surface mounts IC's (smaller then SOIC) so i have gotten decent at it, but i use a small fine point utility knife and gently slide the tip under pin3, then heat the bottom of pin3 with a iron (make sure the tip is tinned) and then leverage the knife on pin2 until pin 3 lifts up. clean up excess solder with solder wick/sucker and your set
good luck.
Dave
resistor values for lifting ground AND LED cbutterworth Tubes / Valves 1 24th January 2007 11:46 PM
Sonic Impact.T-amp. What is this lifting pads? How do I avoid? Skwiddy Class D 9 8th January 2006 11:25 PM
Page generated in 0.07015 seconds (74.01% PHP - 25.99% MySQL) with 11 queries
