Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Let the holy war begin ;) Lukasz on caps
Old 17th April 2009, 03:41 PM   #1
Westerp is offline Westerp  Netherlands
Westerp's Avatar
Default Let the holy war begin ;) Lukasz on caps
http://www.lampizator.eu/UPGRADE/CAP.../captest1.html
There was NO DIFFERENCE WHATSOEVER. Nil. Niente. Nada. Zadnej. Nikakoj. Nihuja
Old 18th April 2009, 07:30 AM   #2
Geek is offline Geek
Geek's Avatar
Love it!
Old 18th April 2009, 09:13 AM   #3
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
His choice of capacitors for the test and particularly the reference are more telling than his conclusions. Guess the rest of the chain is similar.
Old 18th April 2009, 10:29 AM   #4
bequerel is offline bequerel  Norway
"Now I can imagine the audiophile forums being triggered. I will be called a moron, an idiot, ignorant, loonatic, vinoholic, Third Kaczynski, Artur Boruc of Audio, etc. OK. go ahead, I don't read forums anyway."
Thanx!
Old 19th April 2009, 07:49 AM   #5
jitter is offline jitter  Netherlands
jitter's Avatar
Well, I'll be the first one to agree with Lukasz, then... I'm neither proud nor ashamed to say this.
I did some substitutions of decoupling caps a while ago (replacement of 22 uF Roederstein electrolytics with 4.7 uF Wima MKTs, the rest of the chain remained untouched). If there were any differences, they were so small that I couldn't detect them reliably. I'm not afraid to admit this was something I had not expected!
Of course everyone likes to quote the part they like or dislike most, and I'm no different. So, I will quote the part that agrees with something that I already discovered myself a while ago:
Originally written by Lukasz
I mean - you may THINK or at least EXPECT that there should be a difference, but I KNOW it because I actually tried. There is so much self suggestion when we want to believe there should be a difference, for Christ's sake - MUST BE, but our sense of hearing can't possibly have a memory long enough to compare in between soldering of different caps.
Even when I listen to one cap and I cough in the middle - I can't compare the sound pre-cough to post - cough. The subtle differences are all a product of our imagination, and OUR NEED TO JUSTIFY the effort and cost to import and install premium caps over the standard ones.
I could not describe my experiences any better. There's nothing in here that's not agreeing with my own.
You could accuse me of bad hearing, but that would be unjustified. I can hear differences, if they're there. But I've (partially) shed the effects of self suggestion after becoming aware of them. Then you really start hearing with your ears and not your mind...
But.... whatever works for you is fine with me, as long as you accept the fact that it may not work for me (or others) and it's futile trying to convince me (or them) otherwise. "Wrong" or "right" are relative, not absolute.
Old 19th April 2009, 10:07 AM   #6
analog_sa's Avatar
Apart from the fact that MKT are quite poor and can't decouple anything your test is very different from the one Lukasz performed. Not all PS configurations benefit from decoupling and some caps contribute little or nothing. Is it so hard to listen to coupling caps? Preferably not connected immediately after lousy electrolytics in a cheap cd player. And at least MKP.
Old 19th April 2009, 10:31 AM   #7
gainphile is offline gainphile  Australia
gainphile's Avatar
One more myth busted !...
http://gainphile.blogspot.com
Old 19th April 2009, 10:32 AM   #8
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Hi Jitter,
If you cant hear the difference in caps, then your system is not capable of portraying the difference. Its really that simple.
Old 19th April 2009, 10:49 AM   #9
impsick is offline impsick  United States
impsick's Avatar
its so obvious what he did wrong. he wired the A-B switch wrong. Simple mistake.
lol, j/k
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 19th April 2009, 12:51 PM   #10
lowtherdream is offline lowtherdream  Canada
lowtherdream's Avatar
You have to put the capacitors close to your ears to feel the difference. You will hear them sing
surfing the 2nd harmonic ... @@@@
Let the holy war begin ;) Lukasz on capsHide this!Advertise here!
Where to begin with a well-used PL-12D? smiler Analogue Source 6 10th July 2009 12:48 PM
I want to begin but I don't know how!!! nicxxx82 Tubes / Valves 10 31st January 2008 06:18 PM
Where to begin on a PP? d1983 Tubes / Valves 13 22nd March 2007 03:31 AM
Where do I begin? rg8729 Chip Amps 3 4th February 2006 08:11 PM
Where to begin? subcoolman Analogue Source 2 20th June 2005 07:30 AM
