| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am trying to find a 10k gain potentiometer for a yamaha a100 amplifier .
Yamaha stopped stocking parts for that amp 10 years ago ! Its a 4 pin surface mounted pot that also has 2 solder on pins to hold it on the circuit board , plus a 1/4 knob shaft sticking out . It is mounted on a circuit board with the shaft sticking staight out protruding through the amps face (under the meters) . I appreciate any help , these are great amps !! |
#2 |
Hi there, could you post a picture of the pot in the amplifier?Unless you can remove it and take a picture of it alone, that would be better.
OW.
Trans-directional-servo-logamp non-zerocrossing autogain compressing thingamajig |
#3 |
my camera wont take a good picture that small , but I have one I drew on powerpoint .
basically its 1/2"x9/16" 1/4 tall (from the board) it has 2 legs that solder it on the board and a 1/4" knob shaft that extends out . it has 4 wire solder on points . |
#4 |
i found a part like this recently in either mouser or digikey. i had to fix a friends roland drum machine that had a similar part. i searched for pc mount pot and found a few different choices.
certified packrat |
#5 | |
I saw the digikey ones , they were 3 or 5 pin (on the electrical) I dont know if the 5 pin will work mines 4), but cosmetically looks good . I need to look at the mouser ones ! Thanks for looking !!!!! |
#6 |
Did you try partstore.com? I got some hard to find discontinued sony parts from them.
#7 |
just did they had nothing for the a100 ,
but did have some other yamaha stuff . Thanks I bookmarked it . |
#8 | |
Mouser may have it !! |
| yamaha a100 50 watt per chan amp UK | tactix | Swap Meet | 1 | 4th September 2008 09:50 AM |
| FS: Yamaha M-60 amplifier | Jimmy154 | Swap Meet | 20 | 12th April 2008 09:12 PM |
| WTB Yamaha A100 | Paulr | Swap Meet | 4 | 23rd March 2008 10:18 PM |
| Yamaha M-4 Amplifier | _MudPuppy176 | Solid State | 8 | 28th January 2007 09:50 PM |
| Page generated in 0.09037 seconds (76.13% PHP - 23.87% MySQL) with 10 queries |
