How hot may resistors run ? How hot may resistors run ? - Page 2 - diyAudio
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th April 2009, 02:13 PM   #11
tubetvr is offline tubetvr
A 25W Dale is specified for up to 9W without any external heatsink at an ambient temperature of 25C. The surface temperature will then be very high but according to specifications it can safely be as high as 200C. The resistor value will stay inside the tolerance specified which is typically 100ppm/C so even if the resistor increase its temperature 150C the resistor value doesn't change more than 1.5%.
So as long as your ambient temperature doesn't go up much more than 25C you should be alright, (almost even without a heatsink).
Regards Hans
As many others say life time is very dependant on heat, a rule of thumb is that life time reduce by a factor of 2 for every 8 - 10C temperature increase.
How hot may resistors run ?Hide this!Advertise here!
5 Watt Resistors on Aleph 4 and Holco Resistors nicharis Pass Labs 16 8th February 2012 07:50 AM
FS: Resistors, LM3886, speaker terminal, variable resistors, switches and rectifiers chris-man Swap Meet 1 28th May 2009 11:47 AM
Ptc Resistors Ziggy Solid State 4 13th January 2009 01:31 AM
Inductive resistors for source resistors bbakota2000 Pass Labs 12 25th March 2005 11:33 AM
Weird Resistors, anyone know anything about resistors priscared Parts 1 19th March 2004 11:59 AM
Copyright ©1999-2017 diyAudio
