Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th April 2009, 01:26 PM   #1
Pdspecl is offline Pdspecl  United States
Default Help!!! Sonic Frontiers Power 2 - buzzzzzzz
Hello,
I have a Power 2 amp. I started getting a low level buzzing from the left channel speaker and contacted Chris Johnson - Part Connexion. The buzzing (with his advice) was isolated to be coming from the input selector switch - Mute, (-). (+). XLR. The amp is set up to run XLR or single ended. I use the single end set up. Per Chris sometimes - feedback occurs when the switch does not work correctly. Using the part # Chris provided I ordered 2 switches from Digikey.com. I removed all the screws from the back plate (holding all the input/ouput connectors). Problem is I can only pull the cover back about 3/4 of an inch. Some of the wires MAY be short and not allowing cover to slide back more. I may flip the amp over and remove the bottom cover to get a better look. Anyone have any experience working on this amp? Any suggestions?
Note, I was very impressed with Chris's support and tolerance for emails, questions..... Very nice guy.
Thanks,
Paul
Wanted Sonic Frontiers Line 1 and Power 1 or SFS amp jainbaby Swap Meet 2 15th November 2007 02:45 AM
Sonic Frontiers Line 2, please help? henkel Tubes / Valves 2 23rd December 2006 04:40 PM
Sonic Frontiers Power 2SE sonic Tubes / Valves 1 21st June 2004 03:19 PM
Sonic Frontiers and Iris martioz Digital Source 0 17th March 2003 09:56 AM
sonic frontiers SFS-40 Thomas Giz Swap Meet 4 5th February 2003 02:17 AM
Page generated in 0.06286 seconds (65.58% PHP - 34.42% MySQL) with 10 queries
