Other than Black Gate, any other non-polar capacitors
suited for the feedback loop of an amplifier ?
(220uf , 50v)
Might work with 220uf, 25v
I see alot of high voltage films that are massive
in size, physically too big for the printed circuit board.
Anyone make smaller voltage non-electrolytic type ?
(220uf , 50v)
hehe..
Percy has polypropylene, but
the cost is around $60 each
and it's > 4" x 2"..... heh
The design I have calls for 220uf
and it shows a 0.1uf in parallel with
it......
Gonna layout the pcb to accomodate
the Black Gate or two Panasonic FC
caps in series to get non-polar.
Let the user pick which cap to
install...............
This particular circuit is the feedback
loop of the amplifier, do you think
I should use 1uf poly instead of
0.1uf poly ?
it......
0.1uf poly ?
SY said:There's no cap better than no cap at all. Get it out of your feedback loop and use an alternate scheme to get rid of offset.
Referring this schematic
http://www.diyaudio.com/forums/showthread.php?threadid=14104
C5 is the 220uf capacitor in question.
I'm not sure why they need capacitors
here, prevent DC offset as you suggested ?
Marlowe said:Hello thylantyr,
Why not Black Gate?
I reserved a space on my pcb
layout for the black gate, but
I was seeking alternatives,
not many people want to spend
$50 for a small capacitor that
should only cost a buck. hehe
So why don't you get Nichicon ES series from Percy? It will cost you two bucks, but I wouldn't look any further, hehe
Forget the Black Gates.
- Design & Build
- Parts
- 220uf - 50v cap ?
