Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th April 2009, 04:51 PM   #1
Aslund is offline Aslund  Denmark
Default From DIN to RCA
Heya all
I am working a bit with an old turntable I bought, a Lenco L78.
It has a DIN cable, but I was planning to cut the cable and solder some female RCA/phono plugs on, but I am a bit unsure how to do this and where to solder each cable, anyone who could help me with it?
Old 7th April 2009, 05:56 PM   #2
Magura is offline Magura  Denmark
Magura's Avatar
Look up the pin-out of the cartridge. That should make it obvious how to get around.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 7th April 2009, 06:32 PM   #3
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
I presume that you'll find two hots and one (or two ) grounds in that cable ;
easy
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 7th April 2009, 06:45 PM   #4
mjf is online now mjf  Austria
hello.
usually the copper braid is ground.
sometimes one isolator is red = right channel
and the other is white or black = left channel..........
after changing plugs you can do a listening test with a wellknown lp (inverted channels..........?)
greetings...........
Old 7th April 2009, 07:22 PM   #5
h_a is offline h_a  Europe
h_a's Avatar
Yeah and one ground clamped to the chassis somewhere. Using that one mistakenly as hot is an absolute no-no.
Have fun, Hannes
PS: check cartridge-pinout and identify pins/strands using a Multimeter (measure resistance between headshell cables and DIN-pins). Connect your findings following the cartridge-pinout to the RCA and be a happy camper
Page generated in 0.07445 seconds (70.57% PHP - 29.43% MySQL) with 10 queries
