| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi DIYers
I have a Sony US turntable running at 60Hz and I am looking to convert the power from 50Hz (Australia) to 60 Hz. I dont know if there is a DIY solution. (I already have a step down transformer to convert the voltage). Perhaps there is a reasonably priced kit ready to go? Or maybe I am just dreaming ![]() I like the turntable and would like to start using it again thanks ![]() (let me know if I have posted in right part of the forum) |
#2 |
I have a Sony TT and it has sync marks for 50 and 60Hz. Is yours one of those? If not, I think you would have less trouble by converting it to a DC motor. Then use a 317 to vary the speed (or be fancy and have a PLL). Cheers! |
#3 |
Hi Gregg
Thanks for your reply. It doesnt have any strobe marks for 50/60 hz. It is the PS-X60 and it is a very solid performer. A feature of this TT is its existing BSL motor http://www.thevintageknob.org/SONY/s...X60/PSX60.html I will have a chat to my electrical engineer friend and see which of your suggestions he can implement with ease
#4 |
buy, build, borrow a suitably sized audio amplifier and drive it with a 60hz sine source.
- suitably sized = enough power output to drive the TT motor - a simple sine wave osc should not be very difficult to build. - just google... the difficult part will probably be to make sure the amp can handle the load impedance of the motor. depending on what that is, it shouldn't be too bad... (speakers are just a motor anyway...) |
#5 |
OK, mine is a PS-T15.
eclectic2k's advice can work, but motors are HUGELY inductive loads that may destabilize the amp. Cheers! |
#6 | |
actually, I have a hard time believing that there is not some adjustment that might make the 'table work on 50Hz. My old yamaha has a speed adjust that can be used to tweak the speed of the motor. I suppose it probably can't make up for the missing 10 cycles (probably can tune +/- a few %, not 20%) But if it does have some adjustment, you might be able to crack open the turntable ad tweak the circuit - assuming the AC isn't wired straight to the motor...?? |
#7 |
Must determine some details to start off with,
1) AC or DC drive motor? If AC motor, fastest fix is to get hold of a pure sinewave inverter. If DC motor, then have to look for solution else where.... 2) Pulley driven? If belt+pulley mechanism then reduce the total gear ratio... some how... Hope this help. Cheers Ken
Audio_Idiot |
#8 |
A 60Hz inverter and a 12V power supply? Maybe a computer supply would do the job. A small (75W or so) inverter off eBay should be cheap. I don't know if they're usually crystal controlled, though. Now, these inverters aren't a true sine wave, so that might be a problem.
#9 |
So, what happens when you run it on 50Hz? My guess is it will be just fine without any conversion.
#10 |
This is a direct drive turntable with a DC motor, it doesn't care what the Ac line frequency is.
| how to 60hz to 50hz 7KW or more reliable but cheap!?? | JinMTVT | Everything Else | 13 | 12th August 2009 04:23 AM |
| running 50hz appliances on 60hz AC | JinMTVT | Everything Else | 3 | 20th January 2009 01:16 PM |
| Linn 50hz to 60hz? | protos | Analogue Source | 3 | 24th June 2005 08:35 PM |
| 50hz on 60hz | lawbadman | Power Supplies | 10 | 21st April 2005 02:26 AM |
| Converting a 110V 60Hz Garrard 301 to 220V 50Hz | icefox | Analogue Source | 3 | 10th April 2004 06:15 PM |
| Page generated in 0.11203 seconds (81.12% PHP - 18.88% MySQL) with 11 queries |
