| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#21 | |
after this thread started, I was thinking exactly this. - with so many LED lights available these days... Maybe a couple of bright white LED's... LED's should make a nice strobe as there is little to no persistence. thinking out load: couldn't you connect two LED's anti-parallel, directly to the AC transformer? (then you just need a transformer, a couple of LED's, and a resistor?) |
#22 | |
#23 |
Thanks for all the suggestions. I managed to borrow a desk lamp with one of those modern fluorescent tubes
All set up with the lights off and then the results - Speed at 33.3 is spot on according to the strobe disc. Speed at 45 is not so good. It is drifting backwards, counterclockwise. Guess that means it is slow? I figure this is now moving to a how to adjust speed on my PS-X60 question. I appreciate all of your help. At least I know my ears were not playing tricks on me. |
#24 | |
A 45 rpm strobe disc (at 50Hz) should theoretically have 133.33333333 bars on it. But that's impossible to print (a third of a bar) so they round it off to 133 bars. That means a strobe disc is never absolutely accurate for 45rpm! The error may seem small - 0.25%, but it's big in comparison to the accuracy a quartz pll drive can achieve. (A 33.3333 rpm strobe disc requires exactly 180 bars, so there is no error introduced.) |
#25 |
It seems to drift backwards quite slowly. To give it some sense of measure, it takes over a second for one of the bars of the strobe disc to 'move' counter clock wise to the position of the next strobe bar.
I have been thinking about what you said about the number of marks (never realised this! ) and how it would not be accurate measuring 45rpm at 50Hz. Given the 33rpm speed measure is spot on then wouldn't it be highly unlikely for the 45rpm to be out?
#26 |
My quartz PLL tt shows a backward drift of one bar every 4 to 5 seconds on 45 - which I believe is correct.
The Sony manual describes this corrective action: |
#27 |
Thanks again Steerpike! I will see what I can do
| how to 60hz to 50hz 7KW or more reliable but cheap!?? | JinMTVT | Everything Else | 13 | 12th August 2009 04:23 AM |
| running 50hz appliances on 60hz AC | JinMTVT | Everything Else | 3 | 20th January 2009 01:16 PM |
| Linn 50hz to 60hz? | protos | Analogue Source | 3 | 24th June 2005 08:35 PM |
| 50hz on 60hz | lawbadman | Power Supplies | 10 | 21st April 2005 02:26 AM |
| Converting a 110V 60Hz Garrard 301 to 220V 50Hz | icefox | Analogue Source | 3 | 10th April 2004 06:15 PM |
| Page generated in 0.11232 seconds (72.68% PHP - 27.32% MySQL) with 11 queries |
