| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
Since its a DC direct drive, I would suggest installing a mosfet driver to regulate the supply voltage to the motor, you can even use a pot to trim the voltage until you achieve the requive speed. Cheers Ken
Audio_Idiot |
#12 | |
#13 |
Thanks for all your replies. To answer a question, it does run when fed the right voltage thru the stepdown transformer. It is the speed that is the question. I have to buy a strobe light to check it.
#14 | |
All you need to do is get a strobe disc for 50Hz (print out one that you download from the www - try the Vinyl Engine library) It's a quartz PLL drive, so if the speed *is* wrong, it is possibly a fault in the electronics. But the service manual is downloadable for free. I've just had a look at it, and there are internal calibration adjustments for the two speeds.
Steerpike's Toybox |
#15 | |
With incandescent, it's a bit of an eye test, but as Steerpike says, an old fluorescent works nicely. - just make sure the room is fairly dim or dark aside from your "strobe" light
#16 |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#17 |
stick a post it on the turntable.
Count the revolutions for three minutes. 33 1/3RPM comes to 100 revs/3minutes. if you get 99.5 revs you are 0.5% slow. if you get 100 3/4revs you are 0.75%fast. It's that easy. You may find it easier to stopwatch 100revs and see how close to 180seconds you get.
regards Andrew T. |
#18 |
Thanks for the suggestions. I now have a strobe disc and will check it tonight. Trying to find a flourescent light still. Seems like they have gone out of fashion
#19 |
the compact fluorescents have almost replaced the filament type.
regards Andrew T. |
#20 |
You can - if pressed- make up a cheap strobe with any LED, which must be powered by *full-wave rectified* AC, but NO smoothing capacitor. And a suitable current limiting resistor (1k for 12V ac.)
12V full wave rectified AC can be got from an *old* AC wall transformer/adapter, as used for portable tape recorders, answering machines, etc. You need the old style with transformer - not a modern switched-mode one. All you do is chop out the big smoothing capacitor. |
| how to 60hz to 50hz 7KW or more reliable but cheap!?? | JinMTVT | Everything Else | 13 | 12th August 2009 04:23 AM |
| running 50hz appliances on 60hz AC | JinMTVT | Everything Else | 3 | 20th January 2009 01:16 PM |
| Linn 50hz to 60hz? | protos | Analogue Source | 3 | 24th June 2005 08:35 PM |
| 50hz on 60hz | lawbadman | Power Supplies | 10 | 21st April 2005 02:26 AM |
| Converting a 110V 60Hz Garrard 301 to 220V 50Hz | icefox | Analogue Source | 3 | 10th April 2004 06:15 PM |
| Page generated in 0.11609 seconds (80.71% PHP - 19.29% MySQL) with 11 queries |
