| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
On my electric gate/ intercom, there is red LED to show the gate status.
Lately this LED fails - 3 times so far in a year. But each time, it doesn't die completely, it suddenly goes really dim - yet still works. It's switched via a dedicated relay on the microprocessor board, powered from 12V dc, and the series resistor is 1k5, so not excessive current, and no obvious reverse bias. When I replace the LED, the new one work fine instantly, nothing else need repairing. Is this a known failure mode for LEDs? I've never known them to suddenly go dim, yet still work. The forward voltage drop after failure is rather high at over 2V. |
#2 |
I've seen similar behaviour several times from LEDs that have been driven with too much current.
If you have just a standard 5mm LED in there (or something similar) I'd be willing to bet the 6.7mA you have flowing through it is too much and over time it is cooking its self (especialy if the housing it's in can get hot). So you could try swapping out the curent limit resistor for somethinig in the region of 3k or more and see if this stops your problem. |
#3 |
That's still weird though; the books say typical LED current is 15 to 25mA - continuous, and this one is operating way below that. And it's only in use for maybe 30 seconds of blinking, three or four times a day.
It stays at room temperature - it's just in the plastic intercom wall bracket with no electronics. |
#4 |
Uh-huh. I have this with every LED bought from fleabay
My solution that has worked so far is to use a superbright LED and run them at about 600uA current for "standard" brightness. Haven't had one fail since Cheers! |
#5 |
Ahh.. so they could be a flakey batch. They DID come from a Chinese dealer, so really no idea who made them. I guess the plan now is to demand genuine HP or Kingbright.
Thanks for the input. |
#6 |
Maybe they are actually low current LEDs. Try to run one at 5 mA and see how bright it is...
I've seen something similar after a burn in period on some of our products. In one batch a few LEDs had not survived the burn in period (at 70 degrees C) and then the baking of the conformal coating at 90 degrees C. |
| Familiar Sonic Impact Failure Mode? | Buckapound | Class D | 8 | 3rd January 2007 07:58 PM |
| Primary mode of transistor failure | Bama Slamma | Solid State | 1 | 27th October 2006 02:50 AM |
| Using a spdt switch to select between triode mode and pentode mode on a guitar amp. | G | Tubes / Valves | 19 | 15th March 2006 09:15 AM |
| 6C33C-B Failure Mode? | Alastair E | Tubes / Valves | 4 | 2nd July 2005 08:03 AM |
| strange transformer failure mode | capslock | Solid State | 9 | 27th March 2003 09:58 AM |
| Page generated in 0.08290 seconds (73.43% PHP - 26.57% MySQL) with 10 queries |
