Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th April 2009, 10:04 AM   #11
jitter is offline jitter  Netherlands
jitter's Avatar
Default Re: Re: Re: newbie, difference in hook up wire gauges?
Originally posted by Magura
Unless your speakers are situated at the neighbours place, and your amp is still at home, plain lamp chord is going to be beyond significant resistance.
Around here that would be 0.75mm^2.
Magura
Well, I did need more than 15 metres (appr. 50 ft) per channel where I used to live. Now I don't even need 2 m per channel. Of course I didn't replace them with 0.75 mm^2, I just cut the 6 mm^2 ones (which are plain OFC copper cables, BTW) to the right length.
Old 5th April 2009, 11:51 AM   #12
Magura is offline Magura  Denmark
Magura's Avatar
Originally posted by nukaidee
I think these questions are always open for debate. I personally don't believe in 3000$ interconnects, but here is what I found. From personal experience and also some kind of mathematical theory from my electrical engineer uncle, thicker lower gauge copper wire conducts low frequencies better, and thinner, twisted pair silver wire conducts high frequencies better. This has something to do with the power handling, frequency, and susceptible-ness to interference..
From blind testing and from what I feel sounds the best, I am using 1gauge .. yes one gauge copper wire, along side with 2x twisted pair 30gauge silver coated copper.
If you're able to repeat that in a CONTROLLED ABX test, Randy has $1 million for you.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 5th April 2009, 09:03 PM   #13
lol. like i said. personal opinion, could be a multitude of things, how its over laying on my power cables .. movement of speakers etc.
hook up wire Original Burnedfingers Tubes / Valves 5 12th January 2009 07:34 AM
Hook up wire? cjkpkg Tubes / Valves 12 23rd November 2008 12:55 PM
Wire gauges basstard Tubes / Valves 21 18th February 2008 04:21 AM
Newbie Asks: What Gauge Hook Up Wire? JimOfOakCreek Parts 3 8th July 2007 05:02 AM
Hook-up wire strategy. Pls advise a newbie ad010685 Parts 1 6th June 2007 02:26 AM
Page generated in 0.07995 seconds (74.27% PHP - 25.73% MySQL) with 10 queries
