Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th March 2009, 02:48 PM   #1
Default measuring current using 1ohm resistor. How?
Hi, I want to measure the current before an HV regulator. The regulator's V+ input is fed from the plus lead of a smoothing cap located after a diode bridge. The HV reg gnd input is fed from the neg lead of this smoothing cap.
Where do I place the 1 ohm resistor to measure current before the reg? In line with the V+ rail (resistor lead to plus lead of cap with the other R lead to reg's V+ input? Or is it across the plus and neg leads of the smoothing cap? Oh, and how do I size the wattage of the resistor? Under no load, the HV reg measures 178V on input, 70V on output and under load, 138V on input and 50V on output with about 28-33mA running through it. Thanks!
Cheers ~ Mike
Old 29th March 2009, 03:15 PM   #2
bear's Avatar
This is a job for Ohm's law!
E = I x R
The 1 ohm goes in series with the "load". If you want to see the total draw of the regulator plus any load (if a load is applied) then it goes in series with the B+ lead before the regulator.
If you only want to see the draw of the thing being run by the regulator, then you put the 1 ohm between the regulator and the load (thing being run by it).
We then measure the voltage across the 1 ohm resistor and apply ohms law to find the current: E/R = I
How large a resistor? P = I x E
You can substitute there like for I... P = E/R x E or P = E^2/R for example.
Since you stated the max current draw and the voltage you can just pop them into the power equation and then pick a resistor wattage that is above that... higher power is always safer.
ok?
_-_-bear
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Old 29th March 2009, 03:28 PM   #3
Default measuring HV - take care
yes, it's ohm's law.
30 to 50mA through 1r0 does not need a power resistor.
50mA is just 2.5mW and can be passed by any 0.125W or greater resistor.
But if you want accurate results you must measure the test resistor accurately.
5% tolerance is not much good if you need 0.5% in your readings.
50mA passing 1r0 will show 50.0mV +-0.1mV if that is the accuracy of the resistor and multimeter combined.
A 1% multimeter on the 200.0mV scale can read no better than +-2mV.
A 5% resistor can read no better than +-2.5mV on 50mA.
The total tolerance of these combined values will be 4.5mV.
Your reading could be anywhere between 45.5mV and 54.5mV for an actual 50mA current.
regards Andrew T.
Old 29th March 2009, 04:04 PM   #4
thanks guys!
One elementary clarification. by "in series" you mean that the resistor should be "in line" with the V+ rail? I don't need a 2nd 1ohm resistor in the gnd rail, just the plus rail? Again, the plus and neg leads of the smoothing cap (located after a diode bridge) is feeding the HV reg board. So I just solder one lead of the resistor to the plus lead of this cap and the other lead of the resistor to V+ input on the HV board?
Cheers ~ Mike
Old 29th March 2009, 04:30 PM   #5
yes, "in series" means the output current passes through the series resistor.
But I have to ask: are you confident you have the skills/knowledge to work with HV and tube/valve gear?
regards Andrew T.
Old 29th March 2009, 04:37 PM   #6
Thanks Andrew for the clarification. I'm definitely learning as you can tell. The way I keep myself out of trouble is that I *always* ask before doing anything, and I make sure to clarify. Several times if necessary. I always use someone elses circuit that is completely spec'd. I'm comfortable measuring voltage, but haven't measured current except by using ohm's law. Thanks again.
Cheers ~ Mike
Old 29th March 2009, 09:31 PM   #7
In my parts bin, I found a 1 ohm 5% resistor and a 10 ohm 1% R. Would the latter be better to measure the current? The DVM is a fluke 87 model.
Cheers ~ Mike
Old 29th March 2009, 10:08 PM   #8
10r 1% will let you measure to 500mV +-5mV
If the fluke is 0.2% then on 2000mV scale is +-4mV.
Total error range +-9mV, for a 500mV reading is far better than +-4.5mV for a 50.0mV reading, more than ten times better.
Do the numbers, rather than guess.
regards Andrew T.
Old 30th March 2009, 01:02 AM   #9
Thanks very much Andrew. I'll post my results sometime this week. Much appreciated!
Cheers ~ Mike
Old 30th March 2009, 01:56 AM   #10
bear's Avatar
Btw, not sure what ur doing with the regulator(s), but dropping 100volts in the regulator seems a bit excessive... you will have a relatively hot regulator there... of course if it is a low current deal anyhow, maybe the heat won't be too much.
_-_-bear
_-_-bear
Measuring current distortion mashaffer Tubes / Valves 0 25th September 2008 10:37 AM
Measuring Cathode Current Rob11966 Tubes / Valves 7 1st October 2007 11:44 AM
measuring current load jarthel Parts 1 23rd April 2007 10:33 PM
Measuring current with an LCD meter Matttcattt Parts 10 12th May 2004 12:13 AM
Measuring Current Output of an Amp Drew Solid State 10 28th October 2003 04:26 AM
Page generated in 0.09395 seconds (87.14% PHP - 12.86% MySQL) with 11 queries
