| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hey all
![]() I have a quick question... I have a scanner light (looks like knight rider)... it simply scans from left to right, at any speed i want. Now I wanted to attach a variable resistor to it so that i could dim the lights... but for some reason it only dims the first LED (in the 8 led scanner... the first first led dims..) (from off to full on), the rest just get a bit dimmer... but that's it... why is this? should't it dim them fully? is it possible that I have it wired wrong? ie, I have the variable resistor on the wrong wire... the + instead of the -? The scanner module has one + coming out of it and the other 8 wires are negatives that goto the each individual led's (-) lead. I attached the variable resistor to the one + wire (since it's easiest to do...) and i also have a 470ohm resistor before that dimmer resistor... basically I'm bringing the 12 volts down to around 3 volts for the leds... after which i want to use the variable resistor to dim the 3 volts from 3 to 0 or 0 to 3... etc... ![]() the + is wired to each leds + lead, in series... next to next to next to next.... etc... ![]() then the other 8 wires, each goto there respective leds lead. what am i doing wrong???? Also... since leds don't fade... how could I easily get them to fade? I was thinking attaching a capacitor to each leds lead... this way it would fade out a bit... help guys!! ![]() Thanks a bunch. Frank
"There is generally one person in every situation you must never under estimate the power of." - Quote by: Ken Kessey. |
#2 |
as a side note, it's basically exactly like my avatar... lol
| Paralllel configuartion LM3886 - adjusting variable resistors | jmillerdoc | Chip Amps | 9 | 1st June 2009 11:02 PM |
| FS: Resistors, LM3886, speaker terminal, variable resistors, switches and rectifiers | chris-man | Swap Meet | 1 | 28th May 2009 12:47 PM |
| Variable cathode/plate resistors? | ThSpeakerDude88 | Tubes / Valves | 8 | 19th November 2007 05:25 PM |
| 50 or 70-380pf variable trimmer caps required | spudspud | Swap Meet | 0 | 14th September 2006 08:17 PM |
| Trade my blue LEDs for White LEDs | CaliforniaBob | Swap Meet | 7 | 26th March 2004 08:28 AM |
| Page generated in 0.07476 seconds (67.44% PHP - 32.56% MySQL) with 10 queries |
