| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Can you use non-polar electrolytics as local (power supply) decoupling capacitors?
I've searched and found only threads about polar electrolytic caps as coupling caps... My power amp's input diff-amp circuit specifies a 100uf/50v polar electrolytic, but all I have are some (high quality)220uf/50v non-polar electrolytics on hand. Will these work ok? If no, then why not ? -Joe |
#2 |
The nonpolar will work, they are capacitors.
You have paid a premium for the nonpolar capacity, that does not get used in this instance. This results in poor value. Polar capacitors designed specifically for decoupling duty also sell at a premium, but in this case the extra performance is of some benefit. Maybe better value?
regards Andrew T. |
#3 | |
Does this mean that (in my case) Nichicon Muse polar caps will outperform the more expensive Muse NP types? Enough to warrant replacing these NP types? While I'd spend a bit more for better results, are the NP's in any way inferior? Anyone?? -Joe |
#4 |
Hi Joe!
I have done this before and they worked fine; however, I don't know if they are any better/worse than polars in this application. There's quite a bit written about using Black Gate N-series (nonpolar) as decoupling caps, so I don't see where there should be any problems using the Nichicons. Maybe Andrew can elaborate on what benefits a high-grade polar cap would give (maybe related to ESR)? |
#5 |
Thanks Chas
It's not that I can't afford to buy good polar electrolytics, just that I had these lying around and I figure that if they're good enough quality for signal path, that they might be great in a power supply. -Joe |
#6 |
Continuing on the same tangent, I recently came across a metallised polyster film capacitor series that is in standard production which goes as high as 470uF @ 63V. They're certainly wouldn't be cheap, and they're obviously quite chunky, but I guess they would definitely represent and interesting alternative to electrolytics....
And you'd only need 21 of them in parallel to form a 10,000uF @ 63V PSU cap !!!! |
#7 |
Goday Jts audio. Absolutely no advantage using bipolar caps in power supply . Why do it?? Can you give us a reason , Kind regards , Alan .
#8 | |
-Joe |
| PS decoupling caps in Gainclone | ClaveFremen | Chip Amps | 26 | 7th February 2010 03:07 AM |
| tda1541 decoupling caps | weegs | Digital Line Level | 6 | 15th March 2007 04:10 PM |
| Decoupling caps(again) | argonrepublic | Parts | 2 | 10th May 2005 10:32 PM |
| decoupling caps | argonrepublic | Parts | 4 | 8th May 2005 10:20 PM |
| decoupling caps question | audiokid25 | Parts | 6 | 28th October 2004 09:56 PM |
| Page generated in 0.08622 seconds (79.25% PHP - 20.75% MySQL) with 10 queries |
