| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi Guys,
I have 4 0.5ohm/10w power resistors that come in a gold heatsink housing. They have 2 small tabs with mounting holes on the sides. My question is, at what point will i have to mount these to another heatsink? i plan on using them in a CRC arrangement in an Aleph 30 PSU. Will they be ok on their own or should they definitely be mounted down? Similar to this Thanks for your time |
#2 |
You can only get full power rating when bolted to a heat sink. Usually, a chassis is fine for that purpose. Those metal cased resistors tend to be physically small for their size - ie, a 25W unit is about the same physical size as a 5 to 7 watt normal sand-box or dog-bone. With no heat sink in free air you'd have to de-rate somewhat.
#3 |
For those type resistors start looking at mounting options and ambient temps at around 1/2 rated dissapation.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#4 |
Thank's guys, much appreciated.
#5 |
One other thing. If you realy overload one of these heatsink
resistors they can explode. I accidently overloaded a 50w device while not on a heatsink to about 200w for a few seconds and it blew up, sounded like a small firecracker. |
| Modushop.biz heatsinked enclosure + F5 Amplifier (Nearly Complete) incl traffo | rhysh | Swap Meet | 10 | 3rd July 2009 09:08 PM |
| Page generated in 0.06761 seconds (72.55% PHP - 27.45% MySQL) with 10 queries |
