| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#21 |
so long as they are non-inductive (actually low inductance) they will work well. The next thing you have to worry about is the tolerance. Lower the better. So J type will work better than K type. You could also look at 1% tolerance which is the best available.
#22 |
Only I was able to find is MILLS
4pund each at HifiCollective 3.85USD at PartsConnexion But those are 12watt If you can do with 5watt its 1.85USD Often I wonder why the good ol white "cement" has been so "banned" I have seen some with copper leads, and others not They are also different in the way the are coupled at the ends Obviously they are not all alike Fore speaker work I may use them "stripped" Maybe even supply them with new soldered copper leads At one point I thought they sounded much better that way At the present I dont seem to care so much The worst I have heard are alu housed...funny to think they were highly regarded audiohile stuff at some time long ago I believe that very often, much of the expencive audiophile components are just branded "gold" relabelled ordinary industrial items May very well be they really are accidentally better, and the finder should be rewarded But mostly prices are really ridicuously My present amp uses paralelled SMD, which I really dont like....amp sound very nice though
#23 |
Given that low inductance is important, carbon composition springs to mind. They have lower inductance than non-inductive wirewound resistors, or pretty much any other type of resistor. The linearity may be poor, but it's not going to matter at 0R22. They are hard to find though.
https://mrevil.asvachin.eu/ |
#24 | |
Where? I've been cycling through Bydgoszcz a couple of times, nice place. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#25 |
If you break open a ceramic resistor, it looks like a coil of resistive wire.
I doubt inductance of his wirewound resistors will be any oscillation issue with that much power at a low impedance, especially since the resistors are getting paralleled in a sense because of the many parallel output devices they are connected to. Also that's a big amp, to dampen oscillation on a big amp, my experience is to use over the standard of 0.1uf zobel capacitor, especially with amp that drives low impedance loads. The big rectangle capacitors from salvaged computer power supplies, or any mains SMPS HV supply work great. I used 0.22uf/4.7ohm with good results. On this big 2-ohm amp, I'd recommend 0.47uf/0.68uf capacitor with a 2.2ohm zobel resistor. If you can, get metal-film resistors, but they are expensive, but very nice. However, I wouldn't worry about the ceramic wirewounds being a problem. I'm looking forward to seeing more of this amplifier!
You can call me Mad Professor, building crazy experiments in my Electronics Workshop |
#26 |
some years ago, i could not get non-inductive resistors for a new amp design. After trying different approaches, I found that adding a simple disc ceramic cap of about 0.1uF in parallel with a 0.22 ohm wirewound resistor seemed to work well. Has anyone tried this out. I'd like to know if there are different observations to this.
| 400a with hot emitter resistor | j beede | Pass Labs | 3 | 10th January 2008 02:25 PM |
| Is there a rule for the value for emitter resistor | ostie01 | Solid State | 19 | 6th August 2006 11:21 PM |
| Dual Emitter Resistor | glen65 | Solid State | 4 | 29th June 2006 02:55 AM |
| where is the emitter resistor? | homer09 | Solid State | 9 | 21st January 2004 07:38 AM |
| Page generated in 0.09126 seconds (75.42% PHP - 24.58% MySQL) with 10 queries |
