Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st March 2009, 12:45 PM   #1
lowtherdream's Avatar
Default interesting new tube sockets
http://home.att.net/~chimeraone/axialtubesockets.html
surfing the 2nd harmonic ... @@@@
Old 21st March 2009, 01:16 PM   #2
jackinnj's Avatar
Polystyrene has a much low melting point than PTFE and it's dielectric constant is significantly higher than Teflon.
Perhaps before someone goes out and buys the sockets at $50 a pop they should read Bob Pease's (National Semi's analog guru) white-paper on capacitor soakage. In fact, read Pease's entire book on Analog Circuit Design -- it's far less expensive experience than this hocum.
Old 21st March 2009, 01:33 PM   #3
SY's Avatar
To be fair, they claimed that the PS is crosslinked. If true, that raises the service temperature. That would also help make these mechanically stronger than Teflon. But $50 each and a goofy story? Nah.
Generally, crosslinked PS is made from a starting resin which is a copolymer of styrene and divinylbenzene. The resulting material will probably have worse electrical properties than thermoplastic PS, but the advantage is that audiophiles recognize the name "polystyrene" and associate it with "good" components.
There are much better materials out there for this sort of thing. If you want the dielectric constant to be low while retaining good mechanical strength (Teflon is lousy in that respect), I would think that something like Ultem or PPS loaded with phenolic microballoons would do the trick.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 21st March 2009, 01:36 PM   #4
Not sure about the specs ... but they are still new (in my book anyway). I agree that price does not indicate the quality/value of the product. Nevertheless, I am always interested to share and discuss new products, especially because I do not have money to test them
The title says "interesting" and not "magical"
Old 21st March 2009, 01:37 PM   #5
SY's Avatar
BTW, dielectric constant of non-crosslinked PS is indeed higher than PTFE, but not by a lot. 2.4 to 2.1, if memory serves.
Old 21st March 2009, 01:46 PM   #6
jackinnj's Avatar
Yupp, you've got that nice polar molecule...
I could never get the boat and chairs right, that's why I switched to Physics.
Tube sockets 56oval Tubes / Valves 11 11th July 2008 11:01 AM
tube sockets bigpanda Tubes / Valves 1 15th June 2006 09:34 PM
Looking for tube sockets satelitis Tubes / Valves 0 8th May 2006 01:08 PM
Tube Sockets FrankRoss Tubes / Valves 4 19th March 2004 10:48 PM
Tube sockets with the same pin spacing as the tube Andypairo Tubes / Valves 5 15th March 2004 01:08 AM
Page generated in 0.09113 seconds (72.38% PHP - 27.62% MySQL) with 10 queries
