diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   newbie, needing help with vintage capacitors? (http://www.diyaudio.com/forums/parts/140807-newbie-needing-help-vintage-capacitors.html)
Joshua_j 20th March 2009 05:28 PM
Hello All,
Here's my story:
Hey There,
I recently purchased some speakers to repair as a hobby....... ESS AMT 3 Rock Monitors.... these have 2 woofers, 1 midrange, and the heil tweeter. I refoamed them using the Simply Speakers surrounds but leaving the stuffings in.
So after refoaming the speakers..... I discover that one of the midranges did not work..... Mind you that I have no idea what I am doing, but after removing the stuffing from both speakers I discovered that someone had messed with the crossovers!
I have the original schematics and found which cabinet had the original parts......
I have read on the web about speakers and crossovers, but I am not an electrician, nor am I electrically inclined. I am very good with my hands and have built many models over the years and have even resoldered some stuff (I know....big deal.. hahhaha). So, in the end, I need some help....
the crossovers seem to be as such:
ORIGINAL
El CAP
13 MFD 75 NVP
85C 7401
"axial"
ALTERED
orange coated radial x 4
277P
3.5 + 10% - 100 DC
IDF - M 3.5
ORIGINAL
EL CAP
55 MFD 75 VNP
85C 7348
ALTERED
EMC 15x15
55MFD 75VNP
85C 7349
I guess that my questions are as follows.....
1. How important is it to keep the voltage the same as the original? Or does it not matter as long as it is greater than the original?
2. What would be acceptable to replace the original 13 MFD capicitor? 10+3? or like the altered one 3.5 x4 (14MFD total) or would 3.3 x 4 (13.2 MFD) be better?
3. I realise that this is a highly debated issue, but what should one replace the older electrolytics with? Or will changing from electrolytics to the newer substances (polymers) change the sound too much from the original design?
In the end, I just want to get these speakers up and running and sounding good again...
Thank you
Joshua
P.S. I can send pictures if necessary
mjf 20th March 2009 08:47 PM
hello.
you can use the equal voltage rating or a higher (e.g. 100v for 75v) for your caps;
the value of the substituted parts should be close to the original...so 10uf+3,3uf or 3,3ufx4 are a good choice;
change elcaps with elcaps if you want to come close to the original sounds........changing to foil/film/polymer caps can alter the sound significantly..........but if it is better or not you have to decide for yourself (by a listening test),because some like it ,others do not...................
greetings...........
Joshua_j 20th March 2009 11:15 PM
Originally posted by mjf
hello.
Thank you for the info!!! Does radial versus axial make a difference?
mjf 21st March 2009 06:56 AM
usually there is no difference between radial and axial.........
sometimes only the price (radial is cheaper).
Joshua_j 23rd March 2009 04:59 PM
Thank you again. One last question, I guess that I asked indirectly before. What is the advantage to a larger sized capacitor.. ie 55 MFD versus 25+25+5? Is there something different about the electrical or sound properties coming from a large value versus multiple small values? Would the mid bass and treble be more responsive with multiple small values rather than a larger maybe sluggish one? Or does it not work like that?
Joshua
mjf 23rd March 2009 07:01 PM
hello.
if you paralell smaller elcaps to get a bigger value the treble should perform better (this is often done,it should lower the inductivity...........)
but you can add a foil/filmcap to the elcaps that gives you the greater sound effect,in your example this could be 2x25uf elcap and a 5uf (or 4,7uf) "plastic cap" (mkt,mkp,kp.....).this application can alter the sound of your boxes significantly,listen to it!
greetings........
Joshua_j 24th March 2009 03:16 PM
Thank you again. I will post the results and the picks of the final project.
Joshua
Joshua_j 10th April 2009 04:46 PM
Ok, so I finally replaced everything, learned all about soldering and different solders and fluxes and everything.... have back pain from doing everything inside the cabinet because the crossover could not be removed.....
And in typical newbie fashion............ the darn mid-range did not work.....
I learned all about using a mulitmeter and went through all of my wires with continuity tsting, checked each resistor..... and still could not figure it out......
IT WAS THE FUSE TO THE MIDRANGE!!!!!!!!:hot:
So, glad to be a newbie and I hope tht this story entertained... I will still post some before and after picks....
Joshua
mjf 10th April 2009 06:32 PM
yes.............the back pain.............
learning by doing is learning for life........
soldering without burnt fingers and parts,.....how to use a multimeter and finding a stupid flaw........never giving up..............
greetings................
Copyright 1999-2017 diyAudio
