Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
alternative connectors
Old 21st March 2009, 09:55 PM   #11
VivaVee is offline VivaVee  New Zealand
For Redel, try Mouser
Alan
"If you can not measure it, you can not improve it" - Lord Kelvin
Old 21st March 2009, 10:08 PM   #12
The Redel connectors start at ~ USD13 for a two pin connector moving to ~ USD25 for an eight way from Mouser. They might be a god choice for a power supply umbilical cord
Alan
Old 21st March 2009, 10:35 PM   #13
infinia is offline infinia  United States
infinia's Avatar
Originally posted by SY
I use DIN for phono, XLR for line level. I have been sorely tempted by those little gold RF jobs that I see used in a lot of wireless routers...
They are called MCX snap in connectors. SMC with flex coax would be a better choice IMO.
http://www.rfacsolutions.com/rf-connector.php
Old 22nd March 2009, 12:06 AM   #14
dvenardos is offline dvenardos  United States
Originally posted by infinia
XLR are all 3 wire, ie 2 plus shield.
They are great for audio and balanced is hard to beat for an extra boost in S/N ratio (+6dB over SE). They are really good in single ended mode ( psuedo differential) as well.
You can get them up to seven pin, although, I would be using them basically as a DIN, not in balanced mode.
http://www.neutrik.com/us/en/audio/2...oductlist.aspx
Old 22nd March 2009, 02:16 AM   #15
infinia's Avatar
Yes, but always 3 pin for audio. The name of the game is line level compatability with other gear (i.e. standards).
Old 22nd March 2009, 02:40 AM   #16
mpmarino is offline mpmarino  United States
mpmarino's Avatar
I see these being implemented more and more in RF eqpt at work. They are small, quick(snap on), and reliable. I've wondered if they would be valuable as SE connectors...
http://www.amphenolrf.com/products/s...42E006547E17F&
Crazy Yankee.
Old 22nd March 2009, 03:00 AM   #17
nukaidee is offline nukaidee  Canada
those are the ones in wifi antennas. most of them are rated for 100 connects. so if you plan to connect it and leave it there for years etc, I think it will work nicely since the noise ratio is really low. but if you are always moving things around, I'd think twice. Also, there is a limit to the gauge of wire you can use.
Old 22nd March 2009, 08:59 PM   #18
Thanks for all the input guys. I think I am going to go with a mix of standard based stuff and my own custom connections to get the best of both worlds.
Now I just need to go find out what it would take for me to implement balanced stereo inputs.
Old 22nd March 2009, 10:29 PM   #19
balanced stereo.. xlr I still say.
Old 23rd March 2009, 01:19 AM   #20
454Casull is offline 454Casull  Canada
XLR, BNC, Speakon
Although those SMB connectors look pretty sweet. I daresay the cable is not as common as regular RG, though.
alternative connectorsHide this!Advertise here!
old ppi connectors damage Car Audio 7 17th January 2009 12:45 PM
DC connectors ho-humm Power Supplies 0 2nd January 2009 03:33 AM
5 and 7 pin connectors SRMcGee Parts 9 22nd September 2005 10:32 AM
Where could I buy these connectors ? ZERS Digital Source 3 30th August 2004 06:17 PM
Has anyone tried WBT connectors? rdunnit Everything Else 8 18th July 2003 12:47 AM
