| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hello to all. When replacing small electrolytic caps that have polarity markings with lets say orange drop film caps that are NON- polarity marked, how do you install them? Thanks, tom
#2 |
Hello dognut,
If the new cap you are installing has no polarity marking, then it shouldn't matter which way the new cap is installed. The reason that you need to respect polarity on an electrolytic cap is that due to the physics of the design, they will explode if they are wired backwards, trust me. The exception to this are non-polar electrolytics. They are actually two normal electrolytics connected backwards to each other, so that there isn't a polarity as far as the outside world is concerned. Peace, Dave |
#3 | |
Tantalums explode even faster when put the wrong way round! Also, bipolar electrolyics now tend to use the simpler, cheaper, and (IMO less robust) construction of simply applying the rated voltage in each direction, so that cathode and anode are interchangeable. Finally, on film caps, the only possible thing you need to look out for when deciding on mounting direction, is the outer foil issue, which, I believe, is well documented elsewhere on this forum. Cheers, Matt |
| Diode replacements | dognut | Parts | 0 | 28th March 2009 11:41 AM |
| Capacitor & diode replacements | dognut | Parts | 2 | 20th February 2009 11:59 AM |
| replacements | doktor | Solid State | 8 | 10th March 2008 12:11 PM |
| AVF-Series Capacitor Replacements? | Stocker | Parts | 4 | 7th October 2007 06:21 PM |
| RAYT7649 IC replacements | mmerig | Parts | 4 | 21st March 2006 06:09 PM |
| Page generated in 0.07717 seconds (72.23% PHP - 27.77% MySQL) with 10 queries |
