Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
6-Ganged Potentiometers?
Old 21st April 2003, 03:28 AM   #1
EchoWars is offline EchoWars  United States
EchoWars's Avatar
Default 6-Ganged Potentiometers?
OK, I've got a vintage setup, and want to add 5.1 surround. To that end, I recently purchased a DVD player that includes onboard DTS and Dolby Digital decoding, and of course it has the outputs for all the required channels.
I also have a 5-channel amp ready to roll. All I need is something to control the volume from the player, and a 4PDT switch to route the front L-R channels. The switch is fairly easy, but...
...I have searched all over the web, and although several manufacturers make 6-ganged pots, it appears that no one fricken sells 'em (except for some $400 stepped pot...sorry, not interested )
Thoughts, ideas, help???
Old 21st April 2003, 03:40 AM   #2
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Default Re: 6-Ganged Potentiometers?
Well, I suppose you could get 6 regular pots and then go someplace like <a href="http://www.smallparts.com">Small Parts, Inc.</a> and get you some gears and link 'em all together (a gear on each shaft with idler gears between the shaft gears).
Could also use pulleys and belts.
se
Old 21st April 2003, 03:50 AM   #3
Philo is offline Philo  United States
One thing to consider is that surround sound recordings and movies are rarely "balanced" to suit your room and tastes. I would use separate pots for for each channel then adjust as necessary. Check out the April issue of AudioXpress for I am talking about.
Philip
"If you didn't make it with your own two hands, its not really yours".
Old 21st April 2003, 04:21 AM   #4
Orgonom is offline Orgonom
Look here:
www.thel-audio.de
He sell a very good panasonic poti.
Andreas
Old 21st April 2003, 06:19 AM   #5
EchoWars's Avatar
Originally posted by Philo
One thing to consider is that surround sound recordings and movies are rarely &quot;balanced&quot; to suit your room and tastes. I would use separate pots for for each channel then adjust as necessary. Check out the April issue of AudioXpress for I am talking about.
Not really practical. I mean, 6 pots just to turn the volume up or down? And each time I do so, I'm unbalanced again. The player allows 6db of adjustment per channel, so balance should be covered as long as my speaks are sorta close in level.
Look here:
www.thel-audio.de
Andreas
There we go! 48 EU. Now, how to snag one of these, since they say on the site:
Goods order is possible in the following way:
(see also under "trading conditions")
By telephone
(with consultation by Mr. Hartwig)
By fax
By letter
By email unfortunately not possible
Since they are in Germany, I might as well not have found 'em, unless someone in Germany wants to help out....
Old 24th April 2003, 05:08 PM   #6
Da5id4Vz is offline Da5id4Vz  United States
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
Have you looked at or considered the DipChip Electronics relay based attenuator?
Looks like they could accommodate a greater than two channel version without too great a head stand.
http://www.diyaudio.com/forums/showt...threadid=12186
Old 24th April 2003, 05:34 PM   #7
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
6-Ganged Potentiometers? Send a message via AIM to Peter Daniel
How about that?
http://www.brigarelectronics.com/Mer...ategory_Code=P
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 24th April 2003, 05:56 PM   #8
colwaiting is offline colwaiting
colwaiting's Avatar
Default peter....
I have bought the brigar items, and the tracking is dubious. They have a four ganged pot W/ a concentric, center detent, balance control. That balance cannot be used as volume #'s 5& 6. (but it's a decent balance)
You may have one of these- Email me.
and the 4-ganger (alone) has -abysmal tracking.--totally strange curve.
Old 24th April 2003, 06:03 PM   #9
colwaiting's Avatar
Default everybody's got that problem!
The best looking multi -Vc is the analog devices AD 8400-2-3. (IMHO)
The problem is it takes a serial digital interface which some folks should be able to scope out pretty easily, but I can't. Can anyone get his digerati friends to take a look at it?
Old 25th April 2003, 10:45 AM   #10
EchoWars's Avatar
The relay based is a little too spendy for my tastes....seems a lot of trouble to avoid a potentiometer.
Brigar shows a 6-ganged, but doesn't list one for sale.
I do believe I'm going to go with an external decoder with remote. I can't believe it's so damn hard to find a pot in the US...
6-Ganged Potentiometers?Hide this!Advertise here!
Trimming ganged potentiometers with... trimpots? RHosch Parts 1 18th February 2005 10:46 PM
Trimming ganged potentiometers with... trimpots? RHosch Solid State 1 16th February 2005 08:05 PM
6 channel ganged pot daatkins Parts 11 30th October 2002 05:55 AM
