Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th March 2009, 03:45 PM   #1
Garyepe is offline Garyepe  China
Garyepe's Avatar
Send a message via MSN to Garyepe Send a message via Yahoo to Garyepe Send a message via Skype™ to Garyepe
Default How Condenser Microphones Work
Condenser means capacitor, an electronic component which stores energy in the form of an electrostatic field. The term condenser is actually obsolete but has stuck as the name for this type of microphone, which uses a capacitor to convert acoustical energy into electrical energy.
Condenser microphones require power from a battery or external source. The resulting audio signal is stronger signal than that from a dynamic. Condensers also tend to be more sensitive and responsive than dynamics, making them well-suited to capturing subtle nuances in a sound. They are not ideal for high-volume work, as their sensitivity makes them prone to distort.
A capacitor has two plates with a voltage between them. In the condenser mic, one of these plates is made of very light material and acts as the diaphragm. The diaphragm vibrates when struck by sound waves, changing the distance between the two plates and therefore changing the capacitance. Specifically, when the plates are closer together, capacitance increases and a charge current occurs. When the plates are further apart, capacitance decreases and a discharge current occurs.
A voltage is required across the capacitor for this to work. This voltage is supplied either by a battery in the mic or by external phantom power.
The Electret Condenser Microphone
The electret condenser mic uses a special type of capacitor which has a permanent voltage built in during manufacture. This is somewhat like a permanent magnet, in that it doesn't require any external power for operation. However good electret condenders mics usually include a pre-amplifier which does still require power.
Other than this difference, you can think of an electret condenser microphone as being the same as a normal condenser.
xfmrs for microphones hitsware Everything Else 1 8th May 2008 09:46 AM
Difference between microphones Mike150 Tubes / Valves 1 19th May 2006 12:33 AM
SPL microphones? thylantyr Multi-Way 3 18th June 2005 06:19 PM
Please Help My Tube Microphones! northsiderap Tubes / Valves 4 6th May 2005 03:53 AM
Page generated in 0.06411 seconds (69.09% PHP - 30.91% MySQL) with 10 queries
