Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th March 2009, 05:59 AM   #1
Default psu power rating suggestion for 1.2F car capacitor
hi guys
i got a car amplifier and subwofer that i would like to use in my audio systems. i also have 1.2Farad car capacitor. yes 1.2F 24v
i am going to build a psu. i am just wondering whats the rated current that my psu need to handle if i want to use the 1.2F capacitor?
how do i wire the cap? after the regulator or before the regulator? i am planning to use lm317 with 3 or 4 pcs of 2n3055 paralleled to get the boosted current.
TIA
Erwin
Old 13th March 2009, 02:16 AM   #2
btt
Old 13th March 2009, 04:40 PM   #3
try charging it with an lm317 based constant current sink/source (CCS).
Set the CCS to 1A and the maximum dissipation of the 317 is ~ 13.8W for the first couple of seconds.
Similarly use a CCS to discharge it.
regards Andrew T.
Old 14th March 2009, 02:04 AM   #4
unclejed613's Avatar
yup, i'll bet that needs a real slow soft start circuit...... with proper wiring, inrush current for that cap isn't a problem in a car. actually a faster method would be an open frame power supply with foldback current limiting, and a standby/operate relay for the amp driven by a comparator that senses when the cap reaches full charge before it applies power to the amp. likewise you could have a 500 ohm 5 watt resistor on the normally closed contacts of the relay, so when you turn the power off, it will bleed the charge off the cap. also you might find it useful to connect an LED and resistor across the cap so when the LED goes out, it's discharged to about 2V. by all means stay below about 20V with this cap, because when you get very close to the cap's rated voltage, the leakage current WILL become an issue. leakage current generates heat, and heat dries caps out. i've seen large electrolytics (30,000uf/ 35V) in a piece of industrial equipment where the nominal voltage of the supply in the equipment was 28V, but actually ran closer to 30V. these caps dried out in a very short time (some of them less than a year)>
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 14th March 2009, 02:39 AM   #5
hmm looks like not that easy to implement
does the use of 1.2F cap on psu worth the trouble of actually implementing it. i mean sound wise?
TIA
erwin
Old 14th March 2009, 07:13 PM   #6
with an impedance at 20hz of 6 milliohms, yes it would make a difference.
questions on Capacitor rating? nina Chip Amps 11 3rd April 2006 01:01 AM
Oil Capacitor DC vs. AC Voltage Rating valveitude Tubes / Valves 2 10th June 2005 11:45 PM
Small single driver speaker suggestion (and power rating question) percy Full Range 68 17th March 2005 06:04 AM
Capacitor Voltage Rating diyman Solid State 2 21st December 2004 02:49 PM
Capacitor Voltage Rating Super_BQ Parts 14 22nd September 2001 03:50 AM
Page generated in 0.08800 seconds (71.57% PHP - 28.43% MySQL) with 10 queries
